Losing Signal - Dish Network 110
MikeI
3,302
290
Anyone else lose signal strength on Dish Network 110 between 9:30 and 10pm PT on Tuesday night? Particularly WSB, KUSA and WXIA
Yes, My locals went down about 10:25 or so. I've done 3 switch tests and I can only get channels from 148 and 119. 110 doesn't show up. I have the 522, after the tests are done i get an OK under 1 and 3 and an X on 2. Not sure if it's them or me.
I have completely lost the use of my 110 sat did a check switch says no signal all those channels are not working for me. Called dish all i get is a busy signal so it can't be just us. Anyone have any word on what the prob might be?
Thanks. I first lost them about 9:25 and was going to post then, but it came back. Now it's gone and come back 2 or 3 times. Must be a storm in the way some where?
It's cloudy here in Albuquerque, NM but not enough to block out 110. My readings on 110 are at least 124 to 125 -- and now they are down to about 113. Even when it rains hard I don't lose 110 at all.
Also when I pull up the signal screen and select which sat I want to see. It blinks on and off about 3-4 times and then stays solid.
I also have lost 110. It started between midnight and 12:30AM. I ran systems check and 119 and 61.5 are in the green, but 110 is showing red. I did a switch check and the results show no 110. On the systems check instead of showing 110 it is now displaying "Conn" I have the 811 receiver.
goaliebob99 said:
Thinking Something Is Skrewed Up From 110 Or The Uplink..
Maybe DirecTV parked their 110 bird in front of E*8? :D
Does MPEG4 mean longer rec. time with same disk size?
Got 2 510's- 1 Hums loudly
