1) Not all stations will be affected by the repack.Even so the “major” channel number will remain the same regardless of the channel assignment.
So basically people need to rescan periodically if they loose their favorite channel.
Most people don't use OTA..unfortunately1) Not all stations will be affected by the repack.
2) Those stations that are affected will do plenty of promotion regarding when they do their change over.
3) If people LOSE their favorite channel, they should:
check connections
check cable
check antenna aiming
check amplifier (if used)
Not directly at least.Most people don't use OTA..unfortunately
Most run fiber to a head in nowadaysNot directly at least.
Even if you're a cable or satellite subscriber, those may (probably are) relying on OTA for the pickup.
Doubtful. In major markets? Sure. All 200+ markets across the country? Nope.Most run fiber to a head in nowadays
Most stations are now owned by conglomerates ..one major station feeds the smaller stations from a centralized location..they have one master control for everybody..its very easy to run fiber nowDoubtful. In major markets? Sure. All 200+ markets across the country? Nope.
Still doesn't mean it's being done. In my market, Dish gets ALL channels OTA. Direct gets one via fiber, the rest OTA. Spectrum gets all the stations via fiber. The other 50+ (yes, that is the correct number) MVPDs servicing the area? OTA.Most stations are now owned by conglomerates ..one major station feeds the smaller stations from a centralized location..they have one master control for everybody..its very easy to run fiber now
Must be a lot of mom and pop cable companies...what site shows how diush picks up channels?..you have me curious noiwStill doesn't mean it's being done. In my market, Dish gets ALL channels OTA. Direct gets one via fiber, the rest OTA. Spectrum gets all the stations via fiber. The other 50+ (yes, that is the correct number) MVPDs servicing the area? OTA.
Yes, there are a lot of mom and pop cable companies. I don't know of a site listing how Dish picks up the signals. I know people who know people who know how it's done in my market. If you want to find out how your market is done, call one of the local broadcasters and ask for engineering. They should be able to tell you.Must be a lot of mom and pop cable companies...what site shows how diush picks up channels?..you have me curious noiw
check connections
check cable
Why first? Now, maybe if you know the station has changed their channels, sure. But if everything has been working fine, and there's no indication the station made a change, I still say it's more than likely a receiver issue (antenna, cable, amplifier, etc).If you get your channels OTA, you should just rescan thru your Dish receiver FIRST. If you get your channels from Dish, Dish will take care of the problem and you will not notice any change.
ETA: I still don't understand what the repack has to do with keeping satellite TV around.
As we get to the packed configuration we will see ATSC 3 implemented and you will see no loss of quality as we know it.
