I currently have a 5LNB slim mount on my roof... sans the actual dish. I have a arial antenna installed but since the mount is actually mounted to the side of the roof, one of the support arms is blocking me from turning the antenna in the direction I need to aim it at.
SO
What is the best size PVC pipe to either slip over the mast or place in the mast.
I assume if I place it inside the mast, I'd need the OD size of the PVC pipe
and if placed over the mast, I'd need the ID size of the pipe.
Since its not for satellite use - I hope its OKAY to still post here - and it don't need it to be very "tight" as this is as strict of alignment than DBS requirements - and I on;t need about 2ft of height....
thank you all...
SO
thank you all...
