I have used a Hughes SD-HBH standard receiver with no problems since Summer 2004. I recently decided to upgrade to a Hughes HAH-SA, which is from the same family as the SD-HBH but adds a 14-day program guide and Dolby Digital optical output. I bought it used from a reputable online seller.
A Directv tech moved my subscription and access card over to the upgrade receiver, and all seemed well. After I hung up, however, I noticed that local stations were not working. I had "For ordering information please call extension 721..." message. Called D* back and different tech worked with me for 45 minutes but was unable to get locals to come in. We did two or three resets, he deactivated and reactivated the card, cancelled the subscription and reentered it, but nothing worked. He finally said that he had exhausted his options, and that it may be an issue with the receiver.
We switched the subscription back over to the original receiver, and locals were back!
Since then, I have looked at the settings for both receivers, trying to see if anything was different. Both receivers are receiving signals from the same satellites and transponders, except the original receiver is receiving a signal from transponder 26 on satellites 101 and 119, but the replacement is not.
Another difference I see is that the original receiver has Switch Type: Simple while the replacement has Switch Type: None. Also, when I check the signals on individual transponders on the replacement receiver, I get the following message when I check 110 and 119:
I have checked channels 490-494. The original receiver checks out okay on those channels. The replacement receiver does not, however. It checks out on 490-491, but for 492-494 it says "Channel Not Available".
Is this a dish pointing issue? If so, why would the dish be pointed correctly for one receiver and not another of the same brand and generation?
I would certainly appreciate any help!
Dish Pointing Mismatch!
Satellite Found: 101 degrees
