do you think part of my problem is the fact that I have scaned in some sats already. I have loaded fw .2880 and enabled ftp and the loader says something like it con not connect to port 23. Do I need to to factory reset and try again.
Why don't you check to see if the cable and/or NIC setup is proper, by going to: Start/Run/ ping xxx.xxx.xxx.xxx , ie to the IP# of the Azbox. If it returns the pings quickly, your connection and IP#s are OK. If it times out, or says destination unreachable, then you have some issue with either the cable or IP#s.
