Not true - metal case is perfect protection against ESD, while the plastic is work as Van dah Graaf generator under sun and wind conditions.
[Actually, it's bad idea post same question many times in different threads.]
Exactly... the metal will dissipate the static, and it is directly connected to ground. Plastic coating encourages static buildup.Pretty sure metal is a little more conductive of static electricity than coated plastic.
It will build up on outer surface of the plastic cover. Pretty simple stuff to continue discuss your mistake: "it also supposedly helps reduce static buildup from wind and debris...".
