Lnb adaptor for fortec 120cm
davey1
I just got my new (white) fortec 120cm dish, but there was no 40mm lnb holder. You just shove your square lnb into the end of the lnb arm. I want to put an invacom quad on the dish, but I require a 40mm lnb adaptor or a new arm with the 40mm holder. Does anyone know if such an adaptor exists for large dishes? I have also noticed that the lnb arm may be too long to slide the invacom into optimal position. Any suggestions?
The 65mm holder is too large, but they also sell a 40mm one. Looking at the 40mm model, I don't think it will fit on to my lnb arm. The my lnb arm is designed for square lnb's (it is wider then the other fortec lnb arm with the 40mm holder)
Oops! Sorry about that! I clicked too quickly! Missed the 65mm!
Davey1, did you buy your dish from us, recently? Let me know because it should have came with the holder. We have those special holders (not listed on our website). They will fit at the end of the rectangular arm and will hold your normal 40mm LNBF.
C Band, Smallest Size Possible?
Questions about my first motorized dish install
