Celeron Processor :^(
Put on fan blowing on it, and see if that helps. Maybe even an old laptop cooler if you have one. Even if it does, I'd still return it while you can.After using this PC for several days, I've noticed it seems to shut down on its own after a couple of hours, even with Sleep turned off. I'm not sure if it's overheating or what. I think I'm going to return it.
Well??? How is that mini pc doing now? Did you figure out what causes the random shut downs or are you still working with it?After using this PC for several days, I've noticed it seems to shut down on its own after a couple of hours, even with Sleep turned off. I'm not sure if it's overheating or what. I think I'm going to return it.
Just asking....................
Question: If I want to put up a second antenna pointed in a different direction, how do I go about combining the two? Is it as simple as a splitter in reverse?
FYI, got my tuner online (thanks Numb) and it's here.
TV stations received at Satsuma, AL-Pepper tuner1
rabbitears.info
Software install on my Windows server was ridiculously easy.
My current antenna is a UHF/VHF combo pointed southeast towards Baldwin county where the transmitters for Mobile/Pensacola are. I'm wanting to point another UHF southwest towards Mississippi. And maybe a third pointing north eventually if I have good results with the second.Will it be another UHF antenna? Or a VHF?
I have only ever combined one of each.
Mrs Pepper mentioned recently that I tend to get obsessive about things, I have no idea what she's talking about.
You can buy a device called a "Smartkom". I have one, and it'll combine 3 antennas into a single downlead. Televes SmartKom 531981, "Rotor Killer" Antenna Combiner/PreampI'm not an expert on multiple UHF antenna setups. There are others here who can make suggestions, like primestar31
