In the past month or so, I have not been able to pickup Lifetime Real Women (11979 V, 3000 SR) and LPB (12072 H, 16666 SR, FEC 3/5, 8PSK) on AMC 21 @ 125.0°W. Are those channels still there, or did their transponder information change?
LPBS (12072 H 16666) is still there, Lifetime Real Women (11980 V 30000) left that transponder and all the channels on that transponder are encrypted.
What are the paramters your using to get LPBS? I'm using these, 12072 H, 16666 SR, FEC 3/5, 8PSK, Pilot =0, yet no luck on the AZBox.
Those parameters look correct. (I used an estimation method (My SR is off by a little bit) and came up with very similar results: 8PSK 3/5 OFF 16677 29.64 Mbps)
I found that the dish has to be 'dead on' and even then it takes a few seconds for the Azbox to lock.
LPBS was in real good for me all weekend 24 hours a day. Wednesday-yesterday it was real weak in the afternoon and gone by sundown. I read similar info in an old post somewhere....Seems to me its the only channel that I have issues with like that...Blind
Thanks. I will try using the 16677 numbers andsee if it works.Those parameters look correct. (I used an estimation method (My SR is off by a little bit) and came up with very similar results: 8PSK 3/5 OFF 16677 29.64 Mbps)
I always try to peak on 12140 if working with a HD receiver. If its SD only then 12104 works fine. Montana PBS use to be way off when Equity was still around. At 123W remember KTWO ABC? They were at 12104 V 2222 and Montana PBS was next door at 12104. SO you had to move the dish farther west to get a good signal on Montana PBS. With KTWO gone its not that bad anymore but I have seen a little difference in signal on 12140 (the HD transponder) if you peak on that versus the Montana PBS one.
That usually brings in LPBS
They lost their FTA (Free to Air) Satellite Uplink in September 2009 when former owner Equity Broadcasting went into Bankruptcy.
