LG LED TV first impressions
yuccabrevifolia
74
Tehachapi CA
I picked up an LG 42LE5400 LED LCD a couple of weeks ago and thought I might pass along some initial impressions.
First off, I am replacing a year old Sony Bravia 40 inch that inexplicably lost its ability to switch HDMI inputs about a week after it was out of warranty. I also have a 42 inch Vizio Gallevia that I bought a few years ago which has developed video noise problems that makes it unusable after about two hours of use. So I decided not to go with a Sony, which I liked, or a Vizio, which was an incredible bang for the buck at the time.
The first thing that struck me about the LG was how thin it was. I have an attached picture to show this, but to provide a basis for comparison, it is half as thick as the Bravia, and probably a fifth as thick as my three year old Vizio Gallevia. Despite that, it is about as heavy as either. Documentation is spartan at best. Most of what you need to actually put the base together and get it hooked up is in paper form, the rest is on a CD. Fortunately the setup procedure is pretty straightforward after this point, if you have set up a modern TV before. It does take two people to easily put the base on.
There are controls to turn the TV on and off, inputs, volume, and menu on the lower edge of the front of the tv. These are flush mounted bubble switch type things and the print is small and low contrast to the bezel. They are almost impossible to use in low light. The side mounted switches on the Sony and the Vizio were much easier to find and use.
Setup was easy enough. The menuing system is wonderfully graphical compared with anything I have seen before. The menus are a combination of row and column type that have been around forever, and a neat on-screen wheel type for adjusting the picture. I have attached examples of both. There is just about everything a person could want by way of adjustment. There is an automated picture adjustment “wizard' that I did not use. If you look around a bit online there are some people who have already found optimum settings for blackest black and ideal color. I am no expert on any of this, so I located some recommended settings online and used these.
Setting up TV channels relied on an automated search that includes OTA digital, OTA analog, satellite, and cable. One thing that my old Gallevia and the Sony did that the LG will not allow is to add channels to the list. Each scan completely rebuilds the list of found channels. This is important to me because I live in a deep fringe area in the mountains between LA and Bakersfield.CA. I have two separate inputs for two outdoor antennas. I have one pointed toward Bakersfield/Fresno, and another pointed toward Los Angeles to get a couple of specific channels that are within range. I have the antennas on an A/B box. The LG isn't set up to allow me to save information from both antennas. I know there are ways around this, but it is one way that the TV differs from my others.
Another difference is the ability of the tuner to pick up distant stations. The Sony would pick up one station that the neither the Gallevia or the LG can regularly; the CW out of Fresno. To be fair, the tower is 104 miles away, but the Sony could lock it and very seldom did the signal fall to the point where the picture became pixelated. I was able to scan this channel in with the LG last night after trying for two weeks, but the picture is right at the edge of acceptability, sometimes pixelated and sometimes not there at all.
When I started shopping I was going back and forth between the Samsung and the LG. And also back and forth between plasma and LED backlit/edgelit. I decided on LED because it would give me decent blacks and would work well in a bright room. To be honest, the only real deciding factor in LG over Samsung was my LG Blu ray player BD370. The two units sync up well. When I insert a disc into the player the TV changes input. I have read it is also supposed to adapt the TV settings, but I see no evidence of that.
The picture is amazing. As I said above, I didn't use the picture wizard for this, instead I found some settings on a board (maybe AVS forum?) that were supposed to be better than factory settings. In my case they really made a huge difference. The one caveat here being that I had to turn off the energy saving features to set it up. I'll let the pictures I am uploading speak for themselves. It completely changed the experience of gaming on the Wii and more so on the PS3. Details jump out in a way that I have not seen before. After two weeks I am still seeing things that elicit a “wow” while watching. There is still a substantial amount of glare from the screen that you can see in some of the pictures. 480i looks good. 480p looks better, better than on the Sony. I think the darker blacks may help make the picture less noisy at lower resolutions.
The Internet features are really nice-to-haves. I can't say as I have used them very much in the last two weeks. I did set up the Yahoo widgets, and have played with the Youtube application, but that is about it. I have Netflix activated on both the BD player and the Wii that is connected to the TV, so it just seems redundant to have yet another Netflix device. I do like the ability to use the Yahoo widgets to check news headlines. It is much more accessible and complete than the news application on the Wii. The widgets and applications respond very quickly. I don't know what kind of processor runs this TV, but there is no lag as long as your Internet connection is fairly good. You can have multiple profiles set up for the widgets for different users. That seems a bit much for the half dozen widgets included. It makes me wonder if there will be more widgets included in some later firmware update.
It does have an update feature similar to my BD player. It asked to update the firmware the first time I powered up the tv attached to the network. It has the ability to connect wirelessly as well, but that requires a seperate dongle. The attachment point for this dongle looks very proprietary.
The remote has some odd touches, but works well. The input button is near the top of the remote in a line of four buttons labelled energy, av mode, input, and TV. I find I have to really look for the button when I changes sources. Since I have a satellite receiver, a Wii, a PS2, a PS3, an HD DVD player, a DVD player, a Bluray player, and an AV receiver all connected to video sources, this is kind of confusing. There is a facility to rename inputs, which I have not used yet. That will probably help. The navigation in the menus is controlled from four arrow keys with an enter button in the middle. The keys/buttons on the remote are very stiff, and it does take some force to make sure the buttons have “clicked”. There is a Netcast button to bring up the Internet options, and a widgets button that brings up the Yahoo Widgets as a ribbon bar along the bottom of the screen. Nice.
Anyway, the above are just some impressions of this TV. I thought I might pass them along. So far I am very impressed. To be honest, I could easily do away with half of what this TV is capable of and still be perfectly happy. I bought it for the picture, and the picture has far exceeded my expectations. The images below were taken with a cell phone camera so really aren't very true to life. The first two are a lot more representative of what I am seeing here than the four to the right.
Thank you for the excellent review! :up :up
Another update on this TV
I finally got around to installing the Nero Mediahome Essentials software that came with the LG. It was installed on an older dual core Compaq. I have two usb external drives attached with my iTunes library and several movies ripped from DVD in AVI format. I managed to install the software without a hitch even though Windows 7 isn't listed as being supported. I started it up the first time, went to My Media which oddly is in the menu on the TV, not a button on the remote as I would have expected. You can see where it is accessed in one of the pictures above.The LG found the shares from Mediahome and I watched a couple of movies from there without a problem. It streamed well from the wireless on the computer to the wired network connection on the LG. No delays or dropped video/audio.
Then things got a bit weird. The next time I tried to start the software it would not start, just begin to run and then quit. I went to the NERO site and downloaded the latest patch. Still the same problem. So I uninstalled the whole thing and reinstalled, patching it before running it for the first time. It started right up. The next time I tried to use it, it did the same thing, started up and then quit immediately. I think it is a Windows 7 specific problem. Obviously I don't want to have to reinstall every time I use Mediahome.
So I finally installed Tversity, which is a free media server, on the Compaq. It has worked fine for the most part. I'm still trying to figure out how to use this software, so the problems I am having with it are probably user error. It can stream files and Internet content to the LG with little problem, and everything comes up nicely under My Media on the TV.
Still a great TV, but I question the software. I also have an older Gateway desktop that has XP on it. I think the next step is to try to install Mediahome on that and see if it is more stable there. The bottom line is that the TV is still amazing me, but the bundled software seems to have problems with Windows 7.
i just bought a vizio led and i love it. the colors are brilliant.
I was looking at Vizios before I decided on the LG. That QWERTY remote made it really tempting. Being able to actually type in URLs to the TV is a heck of a nice feature, and my old Gallevia was a wonderful TV before the picture started to go. I liked it better than the Sony to tell the truth.
National 3D Demo Days
Giants Patriots game on 9/2 in 3d on Fios
