Does anyone have a LCC with an outdoor antenna? What results do you have ? I was thinking it would be better than the tiny indoor antenna they give you. Thank you.
Does the LLC amplify the signal. I already have an antenna with amp in attic. Works well with tv tuner.
True,Whether the indoor antenna is adequate for you or not depends on the location of the towers that broadcast the channels you want to pick up. An outdoor antenna will get a stronger signal, but as it is a digital signal if you are picking it up with the indoor antenna without interruption there will be zero benefit to an outdoor antenna. A stronger signal won't give you better PQ, either you receive a perfect signal or get nothing.
Looks like my box does not recognize the LCC. Did 2 resets and a "clearmybox". LCC powered up and plugged into usb in back. Shows sat and antenna settings does zip code search and nada. I already know i can get 75 channels via tv tuner. Previously had AM-21 so maybe there is a conflict there.
