Scott Greczkowski said:I BELIEVE these are the release notes for this software.
4. Improved agile UHF modulator performance.
joedoe said:I turned on my 622 at around 5:40 pm PDT and got a scary message: "Your hard drive is corrupted and all recordings are lost!" However after I hit Ok button box rebooted itself and all recordings were in place.
I guess I've interrupted software download because I still on 3.63. I also think that it's not a very good idea to push software in almost prime time.
ralfyguy said:Still the signal levels on 129 (port 3 input) are screwed. What's up with that? Can anybody confirm?
My thought is that this is related to TV2's RF output (or TV2's remote control).cebbigh said:Does this mean we should have more stable UHF OTA reception?
MikeD-C05 said:Why don't you try the check switch ?
1. Run a check switch with no sat cables connected to clear out the matrix.
2. Do a power cord reboot- unplug it for 1 minute and plug back in.
3. Run a check switch with the sat cables connected.
This should help you reset your matrix and allow you to get your receiver reset as well. Try it and see if this helps you Ralphy.
Actually it does both TV1 and TV2 on separate channels.ats7627 said:The UHF agile modulator is the TV2 output. It has nothing to do with OTA reception.
