This Update Contains the OpenTV upgrade so now those who have received this software should be able to tune to Dish Network Channel 100
Mark_AR said:On next update cycle, my 522 went into Hard DIsk Diagnostics & is doing a critical test.
Now I have to wait up to 45 minutes for it to tell me it just toasted itself. :yikes
Scott Greczkowski said:This Update Contains the OpenTV upgrade so now those who have received this software should be able to tune to Dish Network Channel 100
mjrusso45 said:Holy crap. Let us know how it goes!
Mark_AR said:6 Record Plus - Allows you to set 2 recordings at the same time. If the TV you are using is busy, it will push the recording to the other TV.
outlaw93 said:I have tested this new feature by setting up recordings using the Guide and it works great . . . but only on TV2. From TV2, anything you set to record from the guide will set to record on TV1 (which is the default choice under this new Record Plus option) unless there is already a TV1 timer on that timeslot, then it will automatically assign the timer to TV2, very cool.
But when I try to set up recordings using the Guide from TV1 and if I try to record a show from the guide at the same time you have another TV1 timer set up it still gives you the usual timer conflict message.
It would make sense to me for this feature to work from either tuner.
