I just logged in to the partner portal at KVH and found that there is a new flash update wizard available. I'm flashing my Tracvision 4 right now (it says it should add the 129 satellite into the available library).
Other than that, KVH is now offering the VIP 211 and the trisat auto-switch.
Those of you who would like to use a DVR on your boats and RV's will still be stuck with the one satellite feed method, but you can use the autoswitch if you go with the VIP211.
I'm not sure if you need to be logged in for these to be viewable:
http://www.kvh.com/pdf/shared_TS/08_S_ MAR_LND_1.pdf
http://www.kvh.com/pdf/shared_TS/08_ST_MAR_LND_12V_2.pdf
http://www.kvh.com/pdf/shared_TS/08_ST_MAR_LND_3.pdf
If you currently have a KVH unit and Dish, get to upgrading.
