OK. I've always been an oldfasioned one LO per band/per sat kind of guy. The only bandstacked anything I've ever seen was on my DishPro sub years ago, and I didnt need to know exactly how it worked so I didnt bother boneing up on it. Suffice it to say everything I know about bandstacking equipment would fit in a thimble with room for a generous shot of Southern Comfort. (Thank you very much Janis!)
So, trying to get my head around this, here's what I've deduced. If I'm way off someone please put it in "Dummies" terms for me so I can get it.
In this case, there are essentially two LNBs running simotaniously, one in each polar orientation, two different LOs as stated.
Enter a freq value in the STB of 11735/SR=whatever, which tells it "I want to see any signal you find @ 11735 mhz". The STB cares not about polarity, only if 11735 mixes down to a freq within it's passband. That is 950-2150.
The Vertical LNB downconverts anything it finds to 11735-10750 = 965, which is withing the passband of the STB. If there is RF @ 11735/V, the STB =
and displays and politely tells us "Here's your channel" If not, the Vertical LNB brings nothing to the table so the STB ignores it.
Using the same input above, the Horozontal LNB downconverts any signal it finds to 11735-10100 = 1635, also withing the passband of the STB. Again the STB =
and displays and politely tells us "Here's your channel" Same as above if there is no horizontal RF at the desired freq.
Other examples are:
Ku----------------------------
IF1 950-1450---------------
IF2 1600-2100
Rx freq-----------------------
(Ku freq-10750)--------------
(Ku freq-10100)
11700-------------------------------950----------------------1600
11705-------------------------------955----------------------1605
12190------------------------------1440----------------------2090
12195------------------------------1445----------------------2095
12200------------------------------1450----------------------2100
Unless you have a signal at both polarities for the same desired freq input the STB should manage everything fine, although I have gotten so much gain on very strong TPs that I could lock them in either LNB/polarotor orientation! Some boxes would probably show whatever scans in as duplicates (ie Viewsat Plat/Extreme), the CS6000 overwrites previous data so it would likely only retain the last of the two scanned in.
All other parameters or commands, H/V (18/13V), DiSEqC, Echo switches, 22khz, etc should be irrelevant to the LNB(s).
I really dont follow the 22khz=on spec, since that is a per satellite configuration specific setting, not a TP polarity specific one. (If we had FW that allowed per TP selection of the switch controls that would be awesome!)
The only way I see it being pertinent is if the tone selects the desired unit and you have to configure two sat pages per bandstacked LNB assy, however I see no logic in using this configuration:
Page one for vertical TPs, LO=10750 22khz=off.
Page two for horizontal TPs, LO=10100 22khz=on.
That would defeat the purpose of bandstacking, best I can tell. There would be no need to have different LOs since only one would be enabled at a time. However Sadoun posted dual LOs of 10750 and 10100 yet the flyer and id plate on the device only lists 10100
: ( both say 22khz on too???)......hmmmmm
Need any volunteers fro the Beta Testing Team Sadoun?
Am I there or do I need to put on the pointy hat and go sit in the corner?
Attached is a plot of the two LOs against each other referenced by the received frequencies. The Potential Out of Band Use is calculated speculation, not design specs.
