January 19, 2006 - Uplink Activity
I wonder if the apparent failure of a TP on 61.5 threw their plans off. It cuts down on HD LIL for the NE/FL since they have trouble seeing 129 from there.
I dont think it does as they have plenty of room to spare on rainbow one. Everyone kindof forgets that bird is upthere along with echostar 3. Im sure rainbow one has a spare tp on it somewhere :)
I suspect most of the HD Lil was going to orginate from R1 and not E3 anyways. (remeber Spotbeams on R1)
E3 only loss was the transponder, but with them moving SD Lil onto a one dish solution I think E* will be ok for now.
(I really dont miss the international "info" channel 580 anyways) :-)
Don't you think they would have turned on one by now? I've heard several say that R1 isn't capable of transmitting on E3's frequencies though.
But from an engineering standpoint why would you design something that would have gaps in the spectrum it can transmit on?
It depends what they plan for R1. If they turn R1 into spot beam mode, they will of course have a lot of HD-LIL ability. But of course they have some issues:
E3 is fading out. If R-1 is in spot mode the CONUS E3 is going to hurt what they can carry on 61.5. 3 lost TPs to date.
VOOM on R-1 would have to be moved to E3
They would need uplinks for the spots on R-1
So, it is hard to say what they are going to do. If they do not turn on R-1 spots and use it for CONUS they will have 3 less TPs still out on E3, or 3 LIL HD cities without coverage because of the outage. Yes they have spare capacity on R-1 right now, but using it for national coverage eliminates a ton of LIL HD capacity it could have in spot mode.
They need to get busy and build a cheap E3 replacement.
Perhaps the FCC made them do it that way?
Echostar 6 & 8 110W
111 DIY MOVED TO Tp 5 TP Freq. 12.282 Ghz
113 FLVNG MOVED TO Tp 5 TP Freq. 12.282 Ghz
152 CSTV MOVED TO Tp 5 TP Freq. 12.282 Ghz
190 REAL MOVED TO Tp 5 TP Freq. 12.282 Ghz
207 CNBCW MOVED TO Tp 5 TP Freq. 12.282 Ghz
251 WB MOVED Tp 5 TP Freq. 12.282 Ghz
400 TENIS MOVED TO Tp 5 TP Freq. 12.282 Ghz
826 ACDEM MOVED TO Tp 5 TP Freq. 12.282 Ghz
835 TMNDO MOVED TO Tp 5 TP Freq. 12.282 Ghz
854 ESPND MOVED TO Tp 5 TP Freq. 12.282 Ghz
876 DIY MOVED TO Tp 5 TP Freq. 12.282 Ghz
892 CNBCW MOVED TO Tp 5 TP Freq. 12.282 Ghz
7173 WPXX MOVED TO Tp 5 TP Freq. 12.282 Ghz
9038 KBLR MOVED TO Tp 5 TP Freq. 12.282 Ghz
9264 WSIU MOVED TO Tp 5 TP Freq. 12.282 Ghz
493 ULTIM MOVED FROM TO Tp 14 TP Freq. 12.414 Ghz
343 EACTN MOVED TO Tp 14 TP Freq. 12.414 Ghz
834 CENTR Moved TO Tp 14 TP Freq. 12.414 Ghz
7336 WCLP MOVED TO Tp 14 TP Freq. 12.414 Ghz
7486 WVAN MOVED TO Tp 14 TP Freq. 12.414 Ghz
7672 WABW MOVED TO Tp 14 TP Freq. 12.414 Ghz
7706 WCES MOVED TO Tp 14 TP Freq. 12.414 Ghz
8306 WGTV Moved TO Tp 14 TP Freq. 12.414 Ghz
8490 WLS MOVED TO Tp 14 TP Freq. 12.414 Ghz
8491 WBBM Moved TO Tp 14 TP Freq. 12.414 Ghz
8492 WMAQ MOVED TO Tp 14 TP Freq. 12.414 Ghz
8493 WFLD MOVED TO Tp 14 TP Freq. 12.414 Ghz
7882 WDCO MOVED TO Tp 14 TP Freq. 12.414 Ghz
9058 WXGA MOVED TO Tp 14 TP Freq. 12.414 Ghz
229 SHOP MOVED TO Tp 16 TP Freq. 12.443 Ghz
6226 WDBJ MOVED TO Tp 16 TP Freq. 12.443 Ghz
6227 WSLS MOVED TO TP 16 TP Freq. 12.443 Ghz
9403 BYUTV MOVED TO Tp 16 TP Freq. 12.443 Ghz
9280 WSET MOVED TO Tp 16 TP Freq. 12.443 Ghz
9281 WDBJ MOVED TO Tp 16 TP Freq. 12.443 Ghz
9282 WSLS MOVED TO Tp 16 TP Freq. 12.443 Ghz
9283 WFXR MOVED TO Tp 16 TP Freq. 12.443 Ghz
9286 WBRA MOVED TO Tp 16 TP Freq. 12.443 Ghz
8200 KMGH MOVED TO Tp 18 TP Freq. 12472 Ghz
8201 KCNC MOVED TO Tp 18 TP Freq. 12472 Ghz
8202 KUSA MOVED TO Tp 18 TP Freq. 12472 Ghz
8203 KDVR MOVED TO Tp 18 TP Freq. 12472 Ghz
8304 WATL MOVED TO Tp 18 TP Freq. 12472 Ghz
8305 WUPA MOVED TO Tp 18 TP Freq. 12472 Ghz
9350 KATV MOVED TO Tp 20 TP Freq. 12501 Ghz
9351 KTHV MOVED TO Tp 20 TP Freq. 12501 Ghz
9352 KARK MOVED TO Tp 20 TP Freq. 12501 Ghz
9353 KLRT MOVED TO Tp 20 TP Freq. 12501 Ghz
9354 KWBF MOVED TO Tp 20 TP Freq. 12501 Ghz
9355 KASN MOVED TO Tp 20 TP Freq. 12501 Ghz
9356 KETS MOVED TO Tp 20 TP Freq. 12501 Ghz
7501 KAFT MOVED TO Tp 20 TP Freq. 12501 Ghz
839 cnal1 Moved TO Tp 23 TP Freq. 12545 Ghz
257 SPRKY MOVED TO Tp 23 TP Freq. 12.545Ghz
409 CSNWS MOVED TO Tp 23 TP Freq. 12.545Ghz
411 foxw2 MOVED TO Tp 23 TP Freq. 12.545Ghz
437 TUSOU MOVED TO Tp 23 TP Freq. 12.545Ghz
447 alt3 MOVED TO Tp 23 TP Freq. 12.545Ghz
461 SPORT MOVED TO Tp 23 TP Freq. 12.545Ghz
492 FNTSY MOVED TO Tp 23 TP Freq. 12.545Ghz
512 PPV MOVED TO Tp 23 TP Freq. 12.545Ghz
514 PPV MOVED TO Tp 23 TP Freq. 12.545Ghz
515 PPV MOVED TO Tp 23 TP Freq. 12.545Ghz
(TP 25 IS NOW IN THE CLEAR WITH NO PROGRAMMING ON IT )
Echostar 61.5 Rainbow 1 / Echostar 3
657 ONGME ADDED TO Tp 31 Tp Freq. 12.661 Ghz Ongamenet (Korea)
658 BTN ADDED TO Tp 31 Tp Freq. 12.661 Ghz BTN (Korea)
Echostar 148
657 ONGME ADDED TO Tp 29 TP Freq. 12.632 Ghz Ongamenet (Korea)
658 BTN ADDED TO Tp 29 TP Freq. 12.632 Ghz BTN (Korea)
Echostar 121
714 nbn4 ADDED TO Tp 3 TP Freq. 12.253 Ghz
715 rpn9 ADDED TO Tp 3 TP Freq. 12.253 Ghz
716 VIVA ADDED TO Tp 3 TP Freq. 12.253 Ghz
785 CARIB ADDED TO Tp 31 TP Freq. 12.661 Ghz
Echostar 119
9874 CHNL1, REMOVED FROM Tp 16 Tp Freq. 12443 Ghz
9875 CHNL2, REMOVED FROM Tp 16 Tp Freq. 12443 Ghz
9876 CHNL3, REMOVED FROM Tp 16 Tp Freq. 12443 Ghz
9877 CHNL4, REMOVED FROM Tp 16 Tp Freq. 12443 Ghz
jmcgee_jr said:
Thanks bob...hey I posted before about HD DNS is there anything at least uplinkied for NY HD? since im sure thats where the HD DNS will come from for EC
NYC, Chicago, LA and a few other citys were uplinked last week or the week before for HD DNS.. (big 4 only)
RandallA said:
"(TP 25 IS NOW IN THE CLEAR WITH NO PROGRAMMING ON IT )"
Hmmm, wonder what they are gonna use it for. HD?
I dont know... but this uplink report was a pain in my @ss this morning with all these channel moves :)
it was like 50 something moves... If they do use if for hd... atleast bring ESPN2 and UHD over to 110
Olympics HD would seem a possibility due to the temporary existance. The ESPN2 HD and Universal HD do not seem likely as they will need the empty TP to transition to EchoStar 10.
Dishnetwork should read this!
DISH Network Introduces `DishFAMILY' Programming Tier
