Is this normal - Satellite Signal Strength question...
sgupta
66
Hey all,
Have a brief question about my DirecTV install. I've had it for some time without too many problems, but still have a few in bad weather (can't complain too much though). Still, on a clear day, I get:
101 Sat @ ~90-95% Signal Strength
119 Sat @ ~90-95% Signal Strength
110 Sat @ ~80-85% Signal Strength (Updated: Was ~75-80%)
Is this normal variance based on location? Or should there be a way to boost the C (110) Sat's value (would have to have DirecTV come out to tweak the install, which I'm not real anxious to do but would if it can likely be done)?
Thanks!
Okay, good to know that's normal. It gives me problems in bad weather (usually I lose the HD channels on 110 before I lose anything else), but in good to fair weather, no - not really. I just thought if that was abnormal, I should look into fixing it.
Also, tested again today (clearer day), and I still got 90-95 on the other sats, but I got 80-85 on 110, so that's a little better than previously thought.
Thanks for the reply!
Sgupta, what receiver are you using for the signal strength? If it's the H20 or HR20, I think they usually only show signals in the 70s or so. I assume you are using another receiver since you have signal levels in the 90s. On my HR10-250 I have 95-97 across the board for 101, 110, 119, FWIW!
Article on Future HD
