Is the hr24 a dual tuner receiver?
agepag
17
Canada
Just wondering if I would be able to watch one show while recording another at the same time. At the moment I have the h24, but I need another receiver.
yes
The HR20,21,22,23,24 are all dual tuner receivers so you can watch one/record one or record two shows at once
The HR34 is a 5 tuner receiver
Okay thanks. How does the 5 tuner receiver work? I currently have the slimline 5 dish with 1 wire coming into my home, will directv consider the 5 tuner receiver as 5 different tvs and charge me for each one?
No, not unless you have the rvu part of it enabled.
HR34 is used by most people as a 5 tuner DVR at this point. It can serve RVU TV's but there are few of the out there at this point.
Pardon my naivety, but do you need to string 5 lines from the dish to use the HR34?? Or is there another way the signal gets split??
You actually need 7, 5 for the receiver then 2 for the OTA signal...just kidding! It's a SWM only receiver. 1 line from switch or ground block so you don't have a nasty amount of cable hanging around the back of your entertainment center :)
Thanks for the info Hutch, maybe I'll consider upgrading soon.
Boston DMA finally gets PBS HD!
HMC/ HD DVR Receiver Question?
