Hi, this is my first post on this site, lots of good info to be found here! I am on the road at the moment so I don't have all the info with me. My system is a SWM with an SL3-S lnb on an H23-600 receiver. The signal strength on the 101 sat is in the 90's, the 99c and 103 ca, cb are nearly the same except for a few transponders that are in the 40 and 50's, spot beams are all good.
I started getting the searching for signal error recently, plus insert a valid access card error that could be fixed with a reset but got continually worse. Is it possible a bad lnb/ poor signal could cause both these errors? Or maybe the receiver?
The system has worked fine for over a year now so I am just trying to trouble shoot the problem for the time being before I get home.
Thanks.
Thanks.
