Setup: Fortec 90cm, Sonicview 4000, Invacom Quard
I have been trying to setup using (AMC6)-12143 V 2573 since it is at 72 degrees (almost due south from my location). I am able to get 90% signal strength, but the quality is still at 0% even when I try to tweak the elevation and LNDP skew (I should not have to do this with a motorised system, and Invacom quad does not have skew unit son it).
I have however been able to get spectacular quality (85-90%) when I make the receiver turn the motor to the right angle, and then move the pole to find good strength, and tweak the LNB to get quality.
My Question
Since the motor is twisted to the right angle, and the elevation and direction are correct as well as the skew to get 101W - AMC4,
- Can I tweak and adjust these settings to the highest quality and be able to use the satellite as a reference for USALS setup?
- Does the reference satellite for correct USALS setup have to be due south or near there, or does USALS just require any fixed reference point in the sky to be able to properly map the locations of all the other birds?
* I am wondering about these questions because I have so far only been able to get any quality from AMC4 and no other satellite
My Question
