I guess I dont know how to exactly explain it unless you see it. When I hook up the new rcvr, it Dls info from the satellite and gets to 25% and halts for a minute, then without getting to 100%, says,"Acquiring guide data" and just sits there. If I hit menu and check signal strength it sees 101 and all the others its supposed to. I have a triple lnb oval dish. So it sees the satellites and gets a 94% signal. The transponders all seem fine as well, but no video signal seems to be coming thru. As if the rcvr is blocking the signal.
