How do you upgrade to it if your jailbroken?
Or you do a restore update. And then re-jailbreak. The problem with restore is that it clears everything off so you have to reinstall all of your music, pictures, and APPs, and that is before the JB.Put your device into DFU Mode (http://www.ipadforums.net/ipad-hacking/27489-dfu-mode-dummies.html) and restore the iOS version you are moving to using iTunes (in your case, to iOS 6.1.2).
Then follow this tutorial to jail break the iPad using the evasi0n 1.4 tool: http://www.ipadforums.net/showthread.php?t=102722
Once you have finished you should have a clean iPad freshly jailbroken with Cydia on it!
Also prior to that you might wanna do a sync backup on itunes.
Sent from my SPH-L900 using Tapatalk 2
It still has to reinstall everything. Whereas a simple update just updates the firmware only.Backed up everything using iCloud.. And got it all back. Then re-did the jb at back in biz
Sent from my iPad using Tapatalk HD
