May I suggest moving your seating closer to TV area? Why such as huge distance?I have a seating distance of roughly 20' so I am shopping for the largest panel in my budget... Somewhere around $3000.
I wish I was allowed and had the space for a rear projector, that would prob open a whole new set of options.
Same TV or two different ones?My technologically challenged gf was able to tell the difference at about 10-15 ft at Walmart. I have a hard time with it, but she saw it and has no idea what 4k is. That was on a 50".
4k TV are not that expensive anymore. consider this you can buy a 50 inch 2015 smart tv at best buy for $1000 dollars. The brand is a Samsung TV
That's an off-base snipe at Apple. Compared to other phone manufacturers that release a new handset every few months, Apple's phone release cycle is very reasonable. Every time I've upgraded my phone, the new one has been noticeably better. The phone is redesigned every two years and in the in-between years they make the internals a hell of a lot better. I probably won't buy the new phone this year, unless that "little to any difference" in models is something that will greatly improved my normal use of the phone (say a greatly improved camera).I see 8k coming before 4k is even adopted as the new standard for tvs. The tv makers seem hell bent on keeping people upgrading to the next biggest and baddest displays ,not to mention the phone makers do the same thing. Apple is the worst. They come out with a new I phone every year and there is little to any difference in the models except it is NEW. I just bought a Phillips 49" smart hdtv off of Amazon and a 32" Magnavox hdtv for the master bedroom from Target. Both together came to less than $800.00 . I don't see upgrading again for at least 5 years. So 2020 is the next time I will buy a tv -unless I suffer an unexpected loss in between then and now.
So who would use 8k then, Movie theaters?I don't see 8k ever being used at home. The size screen you would need even to see that resolution would be huge. I see 8k being only used for commercial use.
That won't stop them from selling themI don't see 8k ever being used at home. The size screen you would need even to see that resolution would be huge. I see 8k being only used for commercial use.
If it looks that good , I will definitely wait to upgrade to 8k. To me there simply is not much difference between 4k and 1080p on most smaller size tvs. I can only fit around 50" - 55" in my living room. You couldn't see a difference unless you sat right up on it using 4k in that same screen size.That won't stop them from selling them
http://www.digitaltrends.com/home-theater/forget-4k-lgs-98-inch-8k-tv-window-future-weve-waiting/
Then there is no need to upgrade to an 8k either...If it looks that good , I will definitely wait to upgrade to 8k. To me there simply is not much difference between 4k and 1080p on most smaller size tvs. I can only fit around 50" - 55" in my living room. You couldn't see a difference unless you sat right up on it using 4k in that same screen size.
