Intalled New LNB--a problem
Gary Z
942
Seguin, Texas
Installed New LNB--a problem
I added the Xtreme II LNB to my system... works great, nice LNB.
I have a 2x1 switch located after the motor.
LNB 1 is the Xtreme II LNB
LNB 2 is a Dish 300 aimed at 119 for audio, NASA and Angel.
I turned off my receiver with the switch on the back. Installed the new Xtreme II LNB.
Came back inside powered up the receiver, LNB 1 side working great, except now I can get 119 anymore, no signal at all.... was working before I changed the LNB?
LNB L.O. for 119 is set for 11250 LNB power is on. Any ideas as to what could have happened?
Strange, swap ports on the switch (with power down) to see if the problem follows the LNB or the port!
PSB,
I swapped ports and it all worked again.... then swapped ports back to the way they originally were and it won't work. How could that be? Very Strange!
Iceberg said:
do you have the diseqc port set up for the fixed dish to say port 2?
Yes.... what gets me is it worked before I swapped the LNB on port 1 and I did not change any settings before or after, I changed to another Diseqc Switch and it all works again, I guess I fried the old one... I did make sure I had the power off with the switch on the back of the Receiver before I swapped LNB's
Coolsat ??
G10r Kwft & Kwbm
