I have almost completed the reassembly of my 24ft diam dish. I now need to install the lnb onto the button hook and then attach it to the dish.
I am a bit confused about the orientation of the button hook . Would the offset on the button hook be in a vertical plane if the dish was pointing at the horizon ? Does it Matter or will the servo motor cope with any orientation ?
What voltage should I apply to the servo motor to check its operation ?
Access will be difficult when the dish is raised onto its tower so I want to check out as much as possible before it is raised. Thanks for any help
Tony
Tony
