Here's an interesting article from the July/August 2013 issue of The Canadian Amateur on the title subject:
View attachment TCA_2013JulyAug_pgs18_19.pdf
Do you think there are separate laws of electronics depending on how you use your RG-6? If everything is working, don't change it. It's when things don't work that you should consider the basics.Interesting article mostly about CATV. So how does this all relate to FTA and OTA. I'm certainly not going to replace all the quad cable that I have inside and outside the house. Everything is working fine.
Nor will I be redoing all the compression fittings!
