If you are not level in all directions, then the arc that the motor creates/travels will be off. It may match up for certain sats, but you won't get the entire arc of satellites. USALS is just a way to easily position the motor at each point on the arc, so it will not work for all positions (neither will straight diseqc positioning, either since the physical position of the dish will be off regardless)
