Following was my previous setup that was working fine with 2 IRDs.
- Dish 500 with Twin DP LNB; pointed at 110 + 119 bird.
- Dish 300 with Single LNB; ; pointed at 148 bird
- Single (RG6) cable from each Dish (500 &300) going into SW21 switch and output to PVR 501 IRD
- Single (RG6) cable from ONLY Dish 500 to straight DP301.10 IRD
I recently got a another (3rd) TV, so I bought '' Quad DishPro " (with DP logo) lnb from flead bay, that suppose to allow me to connect upto 4 reciever to 110 + 119 birds. I replaced "Twin DP" LNB on dish 500 with "Quad DP" lnb. Now If I connect RG6 directly from dish 500 to IRD, I will get both 110 & 119 satellites.
but now my problem is:
If I connect both dish antennas to SW21 switch, then receiver does not see 110 nor 119. After running check switch, it performs 38 test then show " SW21 3-SAT switch " and lists only 148 bird. Any suggestion why is it not seeing dish 500????????
One more thing, check switch always used to run "38 test" . But if dish 500 with Quad lnb is directly connected, it will run only 2 test and list both birds. not that I am complainging that it gets done in matter of seconds that several minutes. Its kinds strange behavior.
