I am installing a Slimeline swm dish but I all so adding a outdoor HD anntena on the pole below .. what do I need to integrat the 2 together ? a diplexer ? if so how do I run that ,,,,before or after the 4 way swm splitter ?????
A seperate line....
How is that possible I dont think there is a connection on the H25 for a antenna?
You need to add a AM21 OTA tuner to your set up in order to do this.
what do those look like and where can I get one,, MY TV is new and it has 2 hdmi 's which one is going for the directv unit , 1 cable hookup which has cable tv on it and 1 pc hookup
The AM21 hooks into your existing D* recvr.
When looking at this link, the AM21 is the black box sitting on top of the D* recvr.
http://www.solidsignal.com/pview.asp?p=am21&d=directv-am21n-off-air-dual-tuner-(am21)&sku=8546300063
Since it runs through the Directv box, you need to have an active account.
Ok thats fine..but is it something that I tell directv about and they have to turn on? or is it just put on a active box ? after all this is a antenna..
Yes I understandIt's NOT an antenna, it's a tuner. You still need to buy an off-air antenna that is appropriate for your location and the stations you want to receive.
If you diplex OTA you should put band stop filters at every receiver to disable any possibility of coax networking that might try to coexist in the same frequencies.
Are you able to diplex an OTA over the sat feed between the dish, and the swim? Put up an antenna for FM, and would like to get it into the house without running a separate coax.
