4 days ago I had a Genie and 3 clients installed, it was raining outside and when the tech hooked up the receiver and did the dish setup the results show a red x on all the sats and odd/even transponders (all except 110 odd), no problem, the picture looked fine and he blamed it on the clouds/rain. After the tech left I started getting picture break up, I finally unplugged the power inserter and plugged it back in and the picture looked fine for about a day then the problems resurfaced, I called Direct and they set up for the same tech to come out again today, he calls and walks me thru a "update" he wasn't able to complete because of the "rain/clouds" and said that should solve the problem and cancelled the service call. It didn't solve the problem and I went thru the dish setup menu again and got all red x's again and told the tech this and he said that wasn't a problem, I would be ok when the update took effect. Well it's been 8 hours and I'm "pissed", I called direct and tell them about the results of the dish set up and they say the paperwork says the problem is "intermittent" and the tech was here today (remember he cancelled the call). Also I'm not sure I would call it intermittent, I can reset the power inserter to get a watchable signal but the problem eventually returns, "intermittent" sounds like it's a catch all for something they can't/won't resolve. I'm also having problems getting my ipad to connect to the Genie, the Genie is wired directly into my Lynksys wireless router, I can run the network test and it shows it's "networked" but nobody at Direct seems to be concerned about helping me get my Ipad connected. Right now I'm not happy with Direct, I don't know if I have a bad tech, bad receiver or my expectations are too high. Is this a normal Direct experience or have I gotten a bad tech and/or receiver or possibly a bad dish/lnb. Since I'm having signal and network problems I'm leaning towards a bad receiver.
