Incentive Auction Discussion
I am not trip so perhaps I should keep my mouth shut but all I have ever read is mid April. Not sure if that means as close as possible to the 15th or perhaps anytime from the 10th to the 20th.
As I quoted a pundit earlier, she didn't think there would be a public announcement of the assignments -- only the auction results.
From the FCC website.
The results of the repacking process will be announced by public notice and will include any new channel assignments for television stations.
Reactions: primestar31
The Public Notice will contain the new channel assignments when it is released. I am not allowed to offer a timeframe.
- Trip
That's what they said in January. April is a whole new quarter with a decidedly different commission. The latest public notice (March 30) is perhaps less comprehensive:
The FCC will release the Incentive Auction Closing and Channel Reassignment Public Notice in a few weeks. This public notice will announce the results of the reverse and forward auctions and will provide important information, reminders, and details regarding post-auction procedures and the obligations of successful bidders in the reverse and forward auctions.
From a January announcement it is notable that there may be a certain amount of wheeling and dealing going on such that stations may ask for different channel (aka Second Window):
Reassigned stations will have three months to file construction permit applications for any minor changes to their facilities necessary to operate on their new channels. After all stations have filed their initial applications, stations will be permitted to request alternate channels or expanded facilities on their new channels.
It was placed on the website in February. It remains on the website even in April. We will see what they announce. Personally I have more skepticism about the mid April date than on whether it will include channel assignments. But again we will see.
So that nobody is confused or taken by surprised, I've closed all Incentive Auction threads aside from this one this morning, and will close this one to replace with a new sticky one when the FCC releases the new channel assignments.
- Trip
- Trip
Contest and no rules and my entries !!!!!!!!!!!!!!!!!!!!!!!!!!!!
We're removed from the contest.¡!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Some one did the same thing
And they are still in it to win it
The prize should be held!!!
Start over and then let everyone know
What the!!!!! RULES!!. Are not
AFTER your entries have been Taken!!!!
And Then remove removed! Or is it !!
Just out of revenge or spite??
Well, with everything beyond RF36 being cut for tv stations, IF you aren't going to have any channels higher than RF35 in your area, we can use these for LTE filters on our tv antenna systems. They don't pass anything above 600mHz:
Amazon product ASIN B00006JPE6I am glad you brought it into the picture,and!!!! they work quite well !!!!!
Though depending on your market and/or what channels are important to you. You may have wait for up to three years before you can install this, since that is the post-auction time allotted for the clearance of all TV stations off the 600 MHz band to be completed.
Sent from my LGMS550 using Tapatalk
Just enough time to grab a few of them at lower prices, before the sellers jack them even higher in price.
Does anybody have an approximate time frame listing for the various "phases" that are listed in the stations new assignments?
If you read carefully, I think you'll find that the deadline is 39 months from the forthcoming announcement of the auctions results. Phase 1 stations are expected to have completed their transition before August of 2018. Suggesting that the end of the process is the likely interval isn't logical. The chart shows the deadline to be 35 months after the public announcement with some extra weeks for hardship transitions.
It isn't reasonable to assume that the future reception solution is necessarily incompatible with the current channels unless you require an array of precisely tuned antennas.
Of course the NAB and other broadcasters have been applying a full-court press of late trying to convince everyone that the deadline must logically be unrealistic. The only thing that seems unrealistic to me is that they're going to be able to squeeze in ATSC 3.0 but that's entirely the broadcaster's problem.
A consumer yagi should be broadband in able to receive the full range of channels.
In my mind the bottleneck is that a repack is going to cause major frequency shifts for some broadcasters. This is not easily done. The transmitters are high power and designed for a small range of frequencies. Feed lines are balanced for frequencies as well. Antennas are cut to length to optimize SWR at a particular frequency. Even towers are often designed to direct signals based on the broadcast frequency. Moving from a UHF band down to VHF low will very likely cause the broadcaster to replace up to 80% of the equipment, even potentially a new tower. And none of that addresses the ATSC 3.0 topic which is lurking.
It is naive to say that most stations are ready for a quick change. The winners will be those stations already broadcasting VHF.
I was in Lowe's the other day and saw a primarily UHF RCA antenna advertising 4K capability on its packaging. Trying to receive VHF low on a Yagi-Uda that features a reflector of less than three feet in length isn't going to be pretty.
The marketroids seem to be increasingly emboldened to add more and grosser misrepresentations of what their products will do. Oh, but we said "up to" and that makes everything all right.
Reactions: jamesjimcie
I'll give you that one. I was considering a full range antenna. Unfortunately, most of the antenna listings just show the useless 4k or 1080i verbiage and not the intended channels. Most of these flat antennas are going to be absolutely useless on VHF (channels 2-13). Oh, and when you are looking at channels, you need to look at the real channel and not the virtual channel mapping. You can find that on a site like tvfool.
Like those cheap Chinese antennas on Ebay that advertise 150 mile reception. Always good for a laugh. One of my friends has one and I tried it, it performed no better than a typical small profile UHF antenna. And it was flimsy and cheaply built. Would never survive a winter or tornado season here!
View attachment 125702 nice!! my 1967,Plymouth rag top 440 ,2 door coop.
Well you guys are haf right but azz far azz the tower's go most of them are pretty much all set.
Broadcasting and repacking and all the rest have been going On for quite some time.
Why do you think the Fcc is only going to give a short time for the Broadcasting industry a
Time limit,? And yes them cheep antennas so true!!
You got any links or proof that stations have been working on tower, etc, replacements? Especially since they mostly don't know, STILL, what frequency they may be on in the future? And that key piece of data drives tower and equipment decisions?
Ion is now available OTA in Fargo
H&I and Retro TV to move to KJWP
