identify this BUD
Unimesh dish is what it aims at; direction is the lnbf angle; measured from directly under the LNB/feed/polarotor ( or lnbf if the LNB/Feed or lnbf are center of dish w/o offset; also from under the dish plate at the center or horizontal of the dish; or outside circle of the entire dish.If it is Doing the pointing already; the lnbf parts will not return the assembly of the dish to a feedhorn sized focal distance; there are tabs that hold the LNB/feed focal point correct have adjustable tabs for this distance to be set back to perfect using the new scalar; then mounting the lnbf inside it. Running outside new cable finishes the upgrade; and using a lnb/polaroitor is eliminated; making somebody else do the work outside (and removing the snow) is why it is winter maintenance; an every day type of job...good luck F/D is .38 on a Unimesh; and the new LNBf should work great and only needs a single coax to do all the work for your receiver/STB must be the newest and best also; as the broadcasting industry has become very HD and now UHD available using that 7.7 foot dish...
newbie here please help me about c band lnb!
Using C band kit to monitor Inmarsat Aero H/H+
