Ia5 Pain
karim
9
HI I M NEW HERE BUT I BEEN DOING READING THIS FORUM LIKE 4 MONTHS A GO .
MY ZIP CODE IS 92232 [CALEXICO] CALIFORNIA .
COOLSAT 5OOO LNB INVACOM WELL TRUST ME I BEEN DOING A LOT OF READING HERE BEFORE .BUT NO LUCK NO SIGNAL
SET UP LNB SINGLE /FREQ.1075O 22K OFF SKEW -26/ELEVATION 50/AZIMUTH 150 .
NO SIGNAL .
LNB UNIVERSAL /22K ON /LITLLE SIGNAL BUT GOE'S FAST .I DID BLIND SCAM YESTERDAY I GOT PANTAGONE CHANNEL AND SOME OTHER CHANNEL ABOUT 20 .
OK MY DICH IS 76 CM IS THIS GOOD SIZE FOR MY LOCATION .
WELL I BEEN WORKING ON THIS LIKE 7 DAYS NO SIGNAL W THE PROBLEM PLZ AN SM BODY HELP .THANK YOU .:mad: :mad: :cool:
No need to use all capital letters! Its like SHOUTING on a forum!
If its a Universal LNBF the L.O. should be 9750-10600
Code:
                       Calexico, CA 92231
         Latitude 32° 40.992'N Longitude 115° 30.168'W
                       Sat Name Sat Lng Az(t) Az(m)    El  Skew
                      Pas 3R/6B   43.0W  99.7  86.7   6.0 -56.1
                         Pas 1R   45.0W 100.8  87.9   7.7 -55.8
                   Intelsat 705   50.0W 103.8  90.9  11.9 -54.8
                   Intelsat 707   53.0W 105.7  92.7  14.4 -54.1
                   Intelsat 805   55.5W 107.3  94.4  16.5 -53.5
                          Pas 9   58.0W 109.0  96.0  18.6 -52.7
                       Amazonas   61.0W 111.1  98.1  21.1 -51.8
                     EchoStar 3   61.5W 111.4  98.5  21.6 -51.6
                      Rainbow 1   61.5W 111.4  98.5  21.6 -51.6
               Estrela do Sul 1   63.0W 112.5  99.5  22.8 -51.0
                   Brasilsat B2   65.0W 114.0 101.0  24.5 -50.3
                   Brasilsat B1   70.0W 118.0 105.0  28.5 -48.0
                       Nahuel 1   71.8W 119.5 106.5  29.9 -47.1
                      DirecTV 1   72.5W 120.1 107.1  30.5 -46.8
                          AMC 6   72.0W 119.6 106.7  30.1 -47.0
                          SBS 6   74.0W 121.4 108.4  31.7 -45.9
                     Echostar 4   77.0W 124.2 111.2  34.0 -44.1
                          AMC 5   79.0W 126.1 113.2  35.5 -42.8
                      Nimiq 2/3   82.0W 129.2 116.2  37.7 -40.7
                          AMC-9   83.0W 130.3 117.3  38.4 -39.9
                   Brasilsat B3   84.0W 131.4 118.4  39.1 -39.2
                          AMC 2   85.0W 132.5 119.5  39.8 -38.3
                          AMC 3   87.0W 134.8 121.9  41.2 -36.6
                           IA-8   89.0W 137.3 124.3  42.5 -34.8
                      Galaxy 11   91.0W 139.8 126.9  43.7 -32.9
                     Nimiq 1/4i   91.0W 139.8 126.9  43.7 -32.9
                   Brasilsat B4   92.0W 141.2 128.2  44.3 -31.9
                           IA-6   93.0W 142.5 129.5  44.9 -30.8
                      Galaxy 3C   95.0W 145.3 132.3  46.0 -28.6
                           IA-5   97.0W 148.2 135.3  47.0 -26.3
                      Galaxy 4R   99.0W 151.2 138.3  48.0 -23.9
                     Spaceway 2   99.2W 151.6 138.6  48.1 -23.6
                DirecTV 1R/4S/8  101.0W 154.4 141.4  48.9 -21.3
                          AMC 4  101.0W 154.4 141.4  48.9 -21.3
                     Spaceway 1  103.0W 157.7 144.7  49.6 -18.6
                          AMC 1  103.0W 157.7 144.7  49.6 -18.6
                         AMC 15  105.0W 161.1 148.1  50.3 -15.9
                      Anik F1/R  107.3W 165.1 152.1  50.9 -12.5
                      DirecTV 5  109.5W 169.0 156.0  51.4  -9.3
                EchoStar 6/8/10  110.0W 169.9 156.9  51.5  -8.5
                        Anik F2  111.1W 171.9 158.9  51.7  -6.8
                  Solidaridad 2  113.0W 175.4 162.4  51.9  -3.9
                       SatMex 6  113.0W 175.4 162.4  51.9  -3.9
                       SatMex 5  116.8W 182.4 169.4  51.9   2.0
                         AMC-16  119.0W 186.5 173.5  51.8   5.4
                     DirecTV 7s  119.0W 186.5 173.5  51.8   5.4
                     EchoStar 7  119.0W 186.5 173.5  51.8   5.4
          EchoStar 9/Telstar 13  121.0W 190.1 177.1  51.5   8.5
                     Galaxy 10R  123.0W 193.7 180.7  51.1  11.5
                      Galaxy 14  125.0W 197.2 184.3  50.6  14.4
                  Galaxy 13/H 1  127.0W 200.6 187.7  50.0  17.3
 Intelsat Americas 7/Echostar 5  129.0W 204.0 191.0  49.3  20.0
                         AMC 11  131.0W 207.2 194.2  48.4  22.6
                      Galaxy 15  133.0W 210.3 197.3  47.5  25.1
                         AMC 10  135.0W 213.3 200.3  46.5  27.5
                          AMC 7  137.0W 216.1 203.1  45.5  29.7
                          AMC 8  139.0W 218.8 205.9  44.3  31.9
                   EchoStar 1/2  148.0W 229.7 216.8  38.4  39.9
        Satellite Finder is (c) Copyright 2004, P. Lutus
I do not think you are near IA-5. You must be off by 6 deg to West of 97. Pentagon is at 103 W (If my memory is not wrong). You will have to turn the dish to east by a little- less than 1/4". Keep moving slowly, about 1/10" at a time. Good luck!
sorry man i didn't mean it shoutting or what ever .
lnb is invacom should i put it universal and put 22k on .
what about tp shoul i use n=1 .
sorry i m new with this .
pantagone you sad it's 103 w .i think my TS is 146 correct my if im wrong .
According to PSB's chart above, the dish elevation needs to be at 47, not 50
for a transponder, there should be one that looks like
12177 freq
V polarity
23000 symbol rate
use that one
If you are using a compass you will have to adjust for magnetic deviation (could be why your off), I don't have the numbers for your area but I'm sure someone on here could tell you how many degrees to add or subtract if you are using a compass.
12177 freq
V polarity
23000 symbol rate
use that one
i have Invacom SNH-031/Winegard 76cm (31inch) Dish
may be you right i think my symbol rate was 22.000 so today ill try to do this 23000.
i wanna know the 22k should be always off ?
what pid scan ?
manuel scan is it only for tp?
blind scan for channel?
auto scan?
skew is it very important ?
since you have a Universal, set the receiver to Universal. The LNB LO frequency (LNB Power) should deafult to 9750/10600 and 22K should grey out or say auto
what pid scan ?
that allows you to manually enter everything. Don't worry about it
correct
blind scan finds all the frequencies from where the dish is pointed. Thats how you found Pentagon
auto scan?
scans the frequencies set up for that satellite (what's already programmed in the box)
very important. Don't skew the LNB properly and you wont get signal
yes i m using compass but i don't know how to read my true south
Code:
Sat Name Sat Lng Az([B]T[/B]) Az([B]M[/B])    El  Skew
Here is your true south satellite, with Magnetic (On compass) and True Azimuth.
Make sure you are not standing close to the dish or anything metalic as this will through your compass off!
PSB said:
Code:
sorry man i miss understood ok this is my true south .
iceberg thank you man .
ok what about tp should i change them each time or i stick with one ?
becoz i have this meter and each time i change the tp it go loud on most vertical and not loud on horizontal one .
leave it on the transponder I posted...much easier to work with
If you think you are close (and you are...move the dish 1/8" (if you draw a mark on the mast, go 1/8" to yhe right of there) and shuld be on IA5...try a blind scan then.
pbs the truth i been using my compas near the dish and bunch of tools today ill try to do it far way from any stuff .thank you .
ok i will today .it's the n= tp 27 /12177/SB rate 23000.thx .
other question please the meter how to use it ?it keep biping all the time .
well ,hello everyone,First and foremost I want to thank you for making this forum.
second:iceberg and pbs thank you very m....
i got the IA5 today with out your help forget about it i benn doing a lot of reading to decide to go fta but im happy now thank you .
so i did :
lnb /universal/freq 9750.
ele/51
az/153/east /even i don't know how to read the compass very good [remenber i m new ]
skew/-28
so i got signal till 98 very green then i save it then i was watching tv .
i hope this info it's help full to some one else .
calexico california baby [today it's 115 very hot ]
thank you ppl .
Blackbelt TV
What’s the deal with the UPN affiliates on AMC-6(C)
