Shawn95GT said:The dish is aimed at Sol 2 in the pics.
Just wondering if you were able to get any C-BAND channels at Sol 2 and Satmex 5. ?
Cause I've been told that Sol2/Satmex5 both need an 8ft or higher.
Let me know Shawn..
Yes on bothpro-96 said:Just wondering if you were able to get any C-BAND channels at Sol 2 and Satmex 5. ?
Let me know Shawn..![]()
shawn,Shawn95GT said:Well, I go the cable trenched and put the C/Ku feedhorn on - great fun!
I was rewarded with about the same performance on C-band.... and absolutely nothing on Ku.
This Pansat is downright infuriating to operate coming from the Coolsat. I was hoping I could share position numbers between C and Ku but it won't let me assign the position number on the Ku side. I set it and I changes back to Null.
I'm going to try dialing in and storing the position the Ku side and see if it yanks the position number form the C-band side. If so, this VBOX/Pansat combo is useless and I need to slave it to a 'real' c-band receiver.
Did you do it via the receiver or via gtools or similar?drhydro said:shawn,
i had no problem sharing position numbers for c and ku with my pansat
2700a
I did the tweak and save to same position number last night - and got G10R dialed in.drhydro said:shawn,
i assigned the ku sats with same position number as the c band sats, ie g10 cband and g10 ku had the same number, 28 i think. That worked fine for me with the 2700.
The volkswagon channels are on g10, as is upn arkansaw. You should also be able to pick up the outdoor channel on cband. My guess is your not getting enough signal on the ku side to get the weaker transponders. Play with the skew settings in the pansat, it can make a HUGE difference.
Shawn95GT said:I did the tweak and save to same position number last night - and got G10R dialed in.
Interesting on the skew. Might the skew setting for c-band not be optimal for Ku? I'll give that a shot tonight. The Ku side is VERY weak. I'm barely getting spikes up to 30% on Ku. C-band seems happy as can be. I'm going to double check my focal length and maybe adjust the feedhorn in and out of the scaler ring until the signal peaks. I just put it in till the F/D mark matched what I calculated for the dish. I bet moving it around helps.
Thanks for the insight. I'll try the skew and move the feedhorn some. Can't hurt! This thing is close to being right.
Shawn
I've verified that the feedhorn is setup correctly. I think my problem is / was that I didn't have the feedhorn perfectly centered. I've since corrected this (just the other night).WyrTwister said:C band newbie here , but is it possable to get the Ku LNB mounted so the skew is 90 degrees incorrect ? If so , manually add a duplicate set of Trans-Ponders with the opposite polarity ? Does the same polorotor ( on a dual C & Ku feedhorn ) function for both LNB's ?
How large are the holes in the mesh ?
My guess is you may decide to do Ku from the PrimeStar dish ? With the pansat , use a Diesqe switch or a 22 khz switch to change between sats ?
By the way , I am testing C band on a 90 cm offset Ku dish . I would like to ask a favor . You have the prime star dish ? You have an ectra C band LNBF ? If you get time , would you please consider testing the Prime Star dish on C band ? Is it a 48" Prime star ?
Thank you ,
Best of luck ,
Wyr
Shawn95GT said:I've verified that the feedhorn is setup correctly. I think my problem is / was that I didn't have the feedhorn perfectly centered. I've since corrected this (just the other night).
The holes are oblong i nthe mesh - about 1/16" at the widest parts. It's the exact same mesh as is on my 8' Winegard that I recently picked up.
I 'may' end up using the P* for Ku but only if I have to. I'd like to have a single dish that does it all if possible.
My P* dish is one of the small ones. It's a 36x26 oval. I had an ASC421 on it for a little while for the heck of it. I never was able to lock onto anything DVB but I did see some analog channels (QVC, HSN, Jewelry TV). It was all pretty snowey.
The Five footer just keeps on impressing me. sinceI tweaked the feedhorn, I'm going to take some time to re-check how it's tracking the arc. C-band is pretty forgiving but Ku seems finiky on these bigger dishes.
