Or maybe I shouldn't because I'm missing something but when there is a long movie description the "You Might Also Like" icons are covering up the end so I can't read it all. I hate when that happens!
Even without the "you might like" section the long descriptions would get cut off. I don't think it's really affecting it much at all. I myself like the feature and has lead me to watch some shows/movies that I would normally not think of.
My 722k and Hoppers before the update never truncated descriptions. They need to fix it.
Sent from my iPad 2 using Forum Runner
I can't remember ever seeing a receiver that showed the full description when it was pretty long. I never liked that either but I'm use to it.
I don't care for the new info screen either. It's much slower than the old way. Maybe they need to give you the option to turn off the you might also like feature.
It's not the 'You Might Also Like' feature which is to blame with the icon covering up the descriptions. The rest of the text is really not there to be read. This started with S338 changing how view is formatted when you press 'Info' so it places the live TV picture into a small thumbnail view in the upper left hand corner the same as if you are accessing the Guide. If you recall, it never was like this before. For years all Dish receivers, whether Hoppers or Hoppers with Slings, ViPs, and even non-HD receivers used to show the full TV picture underneath with the program description and info in an overlay view. Pressing 'Info' would toggle between solid or see-thru. Lengthy program descriptions have been truncated ever since they changed the format under S338. They could at least have the courtesy to provide a scroll bar to read the rest of the text. I'm not a fan of the new format (as if the TV picture isn't made small enough times while using the Guide and DVR functions).
Yes! Having "record this" as the default is just plain dumb.The main thing is they need to fix the description truncation, and add the close button back.
Then I guess that's how everybody needs to do it then, even though most people pressed OK, as it required ONE click instead of the two or three required when pressing Info, which would cycle the info screen through various stages of translucence.Just press the info button again that will close the info screen. In all the years I've had DISH that is how I have always done it.
The technical term for the new layout is "sucky".It's not the 'You Might Also Like' feature which is to blame with the icon covering up the descriptions. The rest of the text is really not there to be read. This started with S338 changing how view is formatted when you press 'Info' so it places the live TV picture into a small thumbnail view in the upper left hand corner the same as if you are accessing the Guide. If you recall, it never was like this before. For years all Dish receivers, whether Hoppers or Hoppers with Slings, ViPs, and even non-HD receivers used to show the full TV picture underneath with the program description and info in an overlay view. Pressing 'Info' would toggle between solid or see-thru. Lengthy program descriptions have been truncated ever since they changed the format under S338. They could at least have the courtesy to provide a scroll bar to read the rest of the text. I'm not a fan of the new format (as if the TV picture isn't made small enough times while using the Guide and DVR functions).
Or just press the cancel button...one click.Then I guess that's how everybody needs to do it then.
Or.... they can bring back the close button, and have it be the default, so all it requires is ONE click instead of the two or three required when pressing Info.
Or, just have Cancel be the default on-screen button as it's always been, so millions of customers don't unnecessarily need to learn a new way to do something.Or just press the cancel button...one click.
