Ok you have your dish elevation two low and your az too far to the right(west). Of course your not a moron, we all run into things like this in life and we here are more than happy to help. Set your skew to what it is supposed to be for your zip and don't touch it anymore. Make sure your mast is perfectly plump. unhook the wire from the dish to your receiver and run a check switch to clear its matrix. Hook the wire back up and then hook to the 119 side of your lnb. Place a piece of foil over the 110 eye of the lnb and very slowly move back and forth and up and down until you lock onto Sat 119 transponder 11. Then from there just tweak until you ge the best signal. THen re-move foil and run a check switch again and you should have it.
