I need help finding these birds!
djjolietjake
20
Chicago, Ill.
I need some friendly advice on finding the elevation levels for the 101,119, & 110 birds. I need to get these fired up by Friday. I'm using 1.2 meter dishes. Direct Tv is no help ! :hatsoff:
In the installation menu, select 3 LNB and enter your zip number, the receiver will tell you what all this to set your dish.
What is your zip code? For zip 60617 101 should be Az 202 elev. 40/ 110 Az 213 elev.37/ 119 Az. 223 elev.32 hopefully that will get you up and running.:)
Thanks Boba !! I got in touch with someone who confirmed those same #'s. I gotta get these birds before it drops to 8 degrees on Monday ! :hatsoff:
DirecTV/TiVo loses signal at same time every night
H20 Question
