Ok i have a SuperJack II + HB i believe it is.Pro Brand International.Still has the phone number from the manufacture.Still works GREAT! to.I was just wanting to reach out futher to the East and West.Is that possible by getting a longer one. Thank you
Its a SuperJack II + HB it says Pro Brand International even the phone number.Is it possible to get a longer one to reach out further East and West,Yes mine still works to.
Yes you can get a 24" Superjack but you have to be careful that extending the arm too far doesn't cause the dish to flip. How far you can go will depend on the mount.
another thing to consider when making an upgrade
is the new motor 24 v ( most analog receivers are ) is the new motor able to run 24/36 volts ( the v-box pushes at 36 volts , that might be a future upgrade)
my von wise ( and its a little bit more expensive than most motors says it will do both 24V & 36 V)
This might change the subject a little but is my V-Box II better to use for tuneing then my analog receiver or my 4DTV 922 receiver.Im trying to figure the best way to use the equipment i have.
well it depends on who you ask lol
the v box if i understand right is able to make fine tune adjustments with the motor ( small clicks at a time ) it also stores 99 positions
most analog receivers stor 20 or 24 the 4dtv can store 65 ( i think you can manually set them)
its also able to take diseqc commands from a dvb receiver ( so if you tell the dvb receiver to goto g10 --- it tells the v-box to got g10 and it moves the big dish)
this is the method i will eventually goto,
If I were to get a free C-band receiver and 8' dish tomorrow, I'd be inclined to go buy a Vbox...
But then, I really want to do DVB on C-band, not analog nor 4DTV.
Like Gabsphere said above, "it depends on who you ask".
I personally think it doesn't matter if your analog receiver (or VBox positioner) puts out 24 volts or 36 volts. I'm sure the actuator will handle either voltage.
Were back to my original question tho is,Will a 24in work on my 10foot unimesh oe not.Without it messing up my pole mount or something some people of tols me.
