I'm have a local installer that does custom OTA antennas, they have a good reputation.
I'm just a little confused on if I should be using this in conjunction with my HR44.
I'm currently moved, so if the OTA does work with the HR44, would it be an issue that channels show up on my guide outside my area? If that's how it even works?
I only have an HR44 and HR24s, will OTA contents be share amongst receivers if it comes in to the HR44?
I appreciate any advice on the best way to do this, thank you. Oh I also read that the OTA uses some of the HR44s tuners, but I wasn't clear on how that worked or if that just happened if you were recording or if it just grabbed your tuners as long as you had an OTA hookup, which might no be desirable, I think I read it used two tuners, I could be wrong.
