MRV has been updated to show episode titles within groups on remote receivers.
still blank spaces for me
My to-do list seems to have filled out.
The playlist sort changes are now sticky and dont have to be done every time you hit 'list'.
I had one oddity that so far hasnt produced any actual bad results. When I pulled up the playlist, the showing for "Eureka" that most recently recorded was in the merged playlist (I am using the downstairs unit and the show is upstairs) had the red circle with white horizontal line through it that has previously indicated a deleted show that hasnt quite yet disappeared. I was able to play the show and the red circle went away, show was still there.
MRV splatting seems to have been reduced somewhat, or maybe its just been behaving itself this morning.
still blank spaces for me![]()
Maybe this is just well known and I missed it somewhere, but here is my setup...
3 HR20-100s
BASEMENT
OFFICE
LIVINGROOM
BASEMENT had finished the download/restart and was back up. The other two were in the process of restarting (both <20% in step 2 of 2). To my surprise, I could already see AND play the content on the other two even though they hadn't completely finished starting up yet.
So there it is. Share in my amazement or berate me for not knowing about it sooner!![]()
I'm still unable to get MRV working as well but when I go to the network setup it does say it is connected to network but not internet. I seem to remember reading somewhere the reciever was not compatible with the homeportal modem but search is not being my friend lately. the whole home netork runs thru an intel 410T switch then to the modem but still no MRV
Before I moved had an old Microsoft router MN-700 which did let it connect to the internet have not had the oppurtunity to experiment with it. This probably has nothing to do with new CE but I do have to say that a power on appears to be faster to first picture.
No internet connection
R22-100
0x339/DL-7-17-09
NDS channels not being grayed out in All Channels,also NDS channels being listed in Channels I Get.
No audio Signal Meters Test.
Bar color needs to be changed to black so you don't see a gray screen when changing channels ect.R22-100 doesn't have access to change bar color.
Caller ID displaying Unavailable for Name and Number.
Changing channels needs to be faster than 2 seconds.
When your in single live buffer mode and watch two programs on one channel,then when the second program is playing you select Info/More Info/Done.The first program's information is displayed in Info for 5 seconds then it corrects itself to display the second program's information which is the correct information.Workarounds include going in and out of Standby,or first pausing the second watched program then frame advance corrects previous program information issues,also when in DoublePlay swapping tuners corrects previous program information too.
Recording on StarzE-520 12:05 AM watching History International-271,Double Play is engaged.Pause History International-271.Screen Saver appears, while Screen Saver is displayed paused program's picture jumps through Screen Saver in 1/8 second increments back and forth.
Things I like in 0x339.Scrolling through guide good in RF or IR so far.Good Job!.:up
One HR-20-100 took the download and the other never found it. I'm having MRV trouble and wondering if being on different CE's could be part of the problem.
Okay, I take back the MRV splatting reduction. Its still there and plenty. When on either of the two receivers watching the other simultaneously with MRV, its frequently unwatchable. The network is solid, I've tried multiple cables and three different switches with the same results. The receivers? Up until ~3 weeks ago the MRV was good. The CE from 3-4 weeks ago, when the unified playlist went in, triggered the splats. According to my reviews of traffic and reporting from the router and switches, the server side stops sending briefly, then picks up. Variable pause time. Its busy doing something of a higher priority and then picks up where it left off.
I've also had a repeat of the show from the unified playlist that was located on another receiver showing up with the red circle with the white slash through it. On the first attempt to play it gave me an error I havent seen before, that audio and video packets from the server werent sent. On second play, it worked fine.
But when I went to the playlist, sorted by date order...the show was gone. It was the same earlier, but earlier I tried resorting by name and found the show. Figured I was sleep deprived or an idiot and missed it...but the same was true this time (not the sleep deprivation or idiocy)...the show had been listed right next to another show from yesterday and it didnt appear in the playlist until I resorted by name, then it magically reappeared and was also there when I went back to list by date.
Bottom line: there are many, many ghosts still in the MRV machine.
But thats probably okay, I still dont think we're going to see it in the next NR in a week or two. It'll still be a keyword enabled feature that will be worked on in the next CE. Or the one after that.
Maybe the shared list is a cause of some of the problems, but other than the coincidence of the shared list being implemented at the same time as increased MRV flakiness, I'm not sure there any direct correlation.
Surprisingly, I like the unified playlist a lot. I dont really care which dvr my show is on, I just want a list of shows I have available to watch. Having to pick one and go through it, then realize the show I want is on the other and having to switch and go to that one...for me...would be an annoying PITA.
