HR21 and SWiM
Looks like I got some aligning to do on 99c my highest is in the middle 50s. The 103ca is in the 20s and the CB highest is mid 50s too. I just noticed today I'm not getting certain channels which makes sense. I'm guessing these aren't easy to align either.
WAY off! :) Make sure the mast is plumb, then check the skew and elevation settings. Start with the 101 satellite, get those numbers into the mid 90s, then check 99c and 103ca/cb. You may have to adjust the skew a little.
Reactions: ibuildradios
The numbers will be different depending on where you live. If you live further south, they should all be considerably high In the Kansas City areas, they should be in the mid 90's with some in the upper 90's maybe a few 100's. The further north you go the lower the levels will be.
GenieGo Help
Losing signal possibly due to having multiple locations?
