HR20-100 0x18a possible 2nd Tuner issue
cmeans
36
Chicago, IL
Hi,
I first reported this issue in the thread for the most recent update, but I thought it was a Prioritizer/Conflict Manager issue.
After further investigation, it appears that I can no longer record on my 2nd Tuner at all.
Under Setup/Info & Test/System Info:
Features/Tuner:
Tuner 1: SAT, Record
Tuner 2: SAT
Off-Air Tuner 1: ATSC, Record
Off-Air Tuner 2: ATSC, Record
I've tested the signal strength, and both tuners are at 95% or so, so it doesn't appear to be a cable problem. I live in Chicago, and we did have some heavy storms go through, so I would have understood a cable issue.
If this is a bug with the latest update, I realize I'll just have to wait for the next update and hope that, that fixes it, or can I revert to an older version?
If this is not a bug, then I need to make a service call.
Can anyone confirm which it is, so I know what to do?
Thanks.
-Chris
A simple reboot (I should have thought of trying this earlier) seems to have taken care of the 2nd Tuner issue.
I now see:
Features/Tuner:
Tuner 2: SAT, Record
Whew!
-Chris
Not sure if this is a CE issue but after a reset now the b-band converters give me the not connected message on 499. I get testing on the second tuner, I think only one converter is screwed up on tuner1 but there is no way to swap tuners on this thing to check?
Now that is a known bug according to a post I read today - can't even remember where. To test the secod tuner follow this sequence
499 = Tuner 1 Test
CH + = 500 = Tuner 2
CH + = 501 = Tuner 1
499 = Tuner 2 Test
Or the reverse of course.
The active tuner changes with every channel change.
499 = Tuner 1 Test
499 = Tuner 2 Test
Thats good to know. I did it by recording 2 shows then stopping the recordings one at a time and going to 499. Then turning one recording back on and going to the other and turning it off. For some reason both are testing ok now.
D11-500 / Aug. 31 & Sep. 1 / {CE:08:02} - 0x1063
H20-100 / Aug. 31 & Sep. 1 / {CE:08:05} 0x2030
