HR10-250 OTA signal meters
  • Thread starter Thread starter oldguy1
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
oldguy1
49
The OTA signal meters on the HR10-250 show bars for ant in tuner 1 and ant in tuner 2, although there is only one antenna connection.
With only one antenna, how come there is often 2 different signal levels shown? Also, when tuned to a channel, are both tuners signal for the same channel?
On my tuner it is usually the 2nd tuner that shows the lower signal when they are different.
Never mind. I got my answer.
I finally got the two tuners tuned to the same channel and then used the live tv button to switch between the two. One would pixillate all the time; the other - a stable picture.
I remembered my electronics and tuners and, yes a tuner can have problems with specific frequencies.
Is there any easy way to tell what tuner you are using?
Thanks again for the help.
Direct TV Installed in the rain??
DVR install question (dual-tuner)
