My house was built in the 1970s. It originally had a TV antenna somewhere on the roof, and the builder installed three small metal conduits that penetrate the roof and lead down into three rooms (the living room and two of the bedrooms). The wall plates in the rooms suggest that 300 ohm twin lead once ran down through these conduits to feed TV sets in each room.
I could easily strap on a DBS chimney mount and use the conduit to run some RG-6 from a dish down into the living room; my question is: what's the proper way to ground the setup? The wall plate is attached to a "mud ring" (i.e. there is no electrical box behind the plate), so even if I ran a messenger wire down the conduit along with the coax there's nothing convenient to which to attach it, nor is there any obvious grounding point up on the roof.
The conduit provides a nice, neat,clean-looking solution for getting the wiring inside the house; it would really suck to have to run a ground wire along the roof and down the wall.
Any suggestions?
Any suggestions?
