What type of receivers do you have? I am testing it here on a 211k but I know my 722k and 922 have it set for 8 hours and I never have a problem with it going into stand-by early.
the DISH box is going to standby so the TIVO now can not change the channels IE the tivo recordings are nothing but the black screen saying your dish box is in standby press select to continue crap.
Our tivo has line inputs (series 2) with the ir dongle to control the dish box (I miss the old direct tv boxes with the serial connection)
the reason that won't work is we don't user timers. Tivo's record dynamically ie intelligently. you don't pick times you pick "programs" and it finds them "whenever" they are on and records them. handle conflict resolutions etc..
we THINK we might have it setup.
for some reason (I can not even GUESS why) its obeying the disable command now. and we programmed a 0400 timer for the western channel (if there is a tivo recording for that early its most likely to be that channel) to hopefully wake it back up at 4am.
we shall see what happens. its amazing how stupid the dish boxes function. I guess they are trying to force people to use their rather expensive DVR's. why the box needs to reboot every day is insane and why it won't turn back on to the same channel it was on when it turned off is insane.
what a pain
A Pain indeed! I just switched to dish a month ago, we have a DVR upstairs that powers two bedrooms, but downstairs we use windows media center with an xbox360 extender for DVR on the other two TV's. If the Hopper had but one more tuner!! why would you connect 4 TVs to a 3 tuner device anyway? So the auto update was resulting in many recordings of the dish screen saver on windows media center. I tried setting up an auto tune timer on the Vip222k dish receiver for half an hour after the time I set the daily auto update to. This did nothing. I played with the timings a bit but could not get the dish receiver to turn back on after the update... lots of recordings of that black screen saver with the bouncing dish logo and helpful hints". So I then edited the channel change settings in WMC to include the "select key". Unfortunately You can not edit this feature to send the "select" command before the channel number, it occurs after and this would mean the first recording after the update would happen on some random channel instead of the one it is supposed to. So I then set up a manual recording in WMC for like 3 minutes on some random channel about half an hour after the auto update just to get that select command sent autonomously. I will have one trash recording to delete everyday but it will not take up much space. You should be able to accomplish something similar on a Tivo... hope this helps.
(lite bulb! I can set the settings for this particular manual recording to only keep one episode, so no pile up of trash recordings I am so smart)
Beacuse I did a search and this is what came up....geeesh...thanks for help thoWHY REOPEN A 4 YEAR OLD POST? Use your head if you know the receiver needs to show activity change channels during a commercial. Channel up and down can't take more than a minute and will reset the inactivity timer.
You could have posted a new thread and probably been more visible.Beacuse I did a search and this is what came up....geeesh...thanks for help tho
