Hi guys. Another "problem" I have. I have a customer who has a Sony TV that has Twin PIP. The question is, which DISH Network receiver besides the 522 and 322, can you output two different channels from the same receiver. Can the 721 or the 921 output different channels from say, component output and the composite output? If so, how do you enable that functionality? From my experience, the 921 and 721 is designed for 1 TV use with dual-tuner capability for playback/recording only. It's not designed to output two tuners on different audio/video outputs.
So in essence, the only receiver that can do this is the 522 right? The 322 will require 2 remotes to change channels on both tuners. Or, worse comes to worst, have a 811 and a 311 on the same TV again requiring 2 remotes but also 2 receiver charges. What do you guys think we should do? Thanks!
