grydlok said:
It's not hard to hit.
If you set you dish correctly if you hit the 101 you should have the 95w.
i wish that were true.
i get 101 in strong at 90+ but still can't get 95.
with my meter i can detect 95 a little to the right.
This has been a pain in da jazz.
My meter shows signal from 95W lnb. I get another reading from the 95W lnb in the right if I keep moving the dish that way.
But 95 should be close to 101 right?
I get 101. Get a meter reading on the 95, but no channel 497.
Hard boot the ird, Hughes D11-500, autoconfig.
I have 6 by 8 switch by Zinwell. I hook up the 95w IRd to the Flexport 1 input.
Tried the 18V in the 110-119 inputs to.
My zip is 92801, I set the skew to 102, elevation to 50.
I get 101 fine. I can even get the 119 if I aim that way.
My mast is dead straight up.
I tried 46-48 degrees as well.
I cannot get tone from the left when I lock 101. I get strong tone from 95W when I turn the dish to the right of 101.
