After fighting off pneumonia & hernia surgery the last 2 months, I finally was okay enough to get up on the roof yesterday to adjust my 1 meter (39 inch) Fortec Star dish with Stab HH120 motor. My major problem when the cold weather hit in January, had been too low a signal level for all channels on 97.0W - my South Bird. Before I went up, the only transponder I could get any response at all from was 12007 which was S =57 and Q = 10 %. (ViewSat Receiver). Ran the Sat Receiver thru my VCR on this Transponder and went up and started by tilting the Dish Slightly up without even loosening the Elevation Bolts. The Dish did move up just a bit. Previous elevation setting had been about 32 degrees.
Came down the ladder & to my surprise 12007 had improved to S = 67 and Q = 88 to 100%!! Checked a whole bunch of other transponders including IceBergs' recommended - 12152 which had S = 71 and Q = 61, and 12177 was S = 71 and Q = 75. Performance on every channel I checked on 97.0W was much improved.
My question: are these Q levels of 75 for 12177, and 61 for 12152 okay? That is, how do you know when you've reached the best performance possible?? And does this means I need to rescan each Satellite again?
