how much cement for dish pole?
So if my radius of the hole was 1 FOOT in diameter, like Brian says, and 3.5 feet deep, using 80lb bags of cement, that covers .60 square feet a bag, the calculator says I need at least 18 bags right? If not, why is the math always way off?? I'm supposed to divide 11/.60 correct? Or is it 11/28.2, making the number higher??
Sent from my SAMSUNG-SM-G890A using the SatelliteGuys app!
Remember diameter is the actual distance across the hole and the radius is half that. So if you had a 1 foot diameter hole it has a radius of 6 inches or .5 feet so using the calculator input .5 for radius, 3.5 for height and set units to feet. That gets you 2.75 cubic feet. Divide 2.75 by the yield per 80 lb bag of .60 cubic feet and you get 4.58 bags. Now if you actually mean a radius of 1 foot then the hole is actually 2 feet in diameter so you get 11 cubic feet divided by .60 cubic feet per bag = 18.33 bags.
Oh, that's what was messing me up was the radius thing. Jeeze, stupid dumb math. I talked to my older brother about it on the phone, he brought up some kind of Quickrete hole calculator; maybe like Brian did. My brother came up with 5 bags too, so I should round up to 6 bags actually for the inside of the post too. I can afford 5 or 6 bags alot easier than 18 or more. I've helped my dad plant posts several times in the yard before, I don't remember using more than 3 bags at a time.
Reactions: FTA4PA
Hopefully after I get my C-Band dish relocated to another pole, I can maybe finally get my years of motorized misalignment sorted out. My true south satellite is 85W, and there's nothing on it usually to tune in. The Dish Uplink Center Cheyenne Slate has been long gone, never knew why.
I think how much cement you use in a hole is a bit like a discussion of religion or politics - everybody's got an opinion, and some will defend theirs to the death. I have always used a minimal approach, which means I use a old-time post hole digger that digs a hole maybe 4 to 5 feet deep and maybe 8 to 10 inches across at the top, I've never actually measured it. I've dropped my pole in that, and used between three and five bags of concrete mix to fill it. And I have never drilled holes in the pole or welded anything to it. So far have never had a problem. I do it this way for a few reasons:
- I don't live in an area where we get hurricanes. And I wouldn't, but if I did I'd definitely go wider and use more concrete.
- I don't have a welder and don't know anyone who does, and I'm too lazy to drill holes through solid metal.
- Where I live there are tree roots EVERYWHERE, even if there are no trees currently close to the dish. So again, laziness prevents me from digging a wider hole than necessary. However it does also mean that if I hit a large tree root on the way down I may have to dig to the side of it, which means the resulting hole will be bigger. This is why the amount of concrete can vary.
- If I happen to have small chunks of old broken concrete lying around I will throw them into the wet cement, both to get rid of them and to decrease the amount of concrete mix needed. I use bigger chunks if I've had to enlarge the hole because I hit a big tree root!
- I usually bury a hunk of old irrigation pipe taped to the pole and bent outwards to where my trench will be, so the wires will be protected where they enter the ground. Actually I've always used plastic pipe all the way to the house so that in future digs there is some protection before I hit the wire. This has saved my wires on more than one occasion. A roll of ¾" or 1" diameter black plastic irrigation tubing is pretty cheap at many home improvement stores, just be sure you oversize it a little for the number of wires you'll be running, or use electrician's wire pulling lubricant if you get into a tight spot. If you use a continuous length of tubing then seal the exposed open ends with pure silicone caulk after you have run the wires, to keep water from collecting inside.
I have never had a problem with a pole turning in concrete. I am not saying it can't happen, and if by some chance you got a brand new hunk of pipe that is smooth on the outside, or if you make your concrete mix much too dry so it can't flow around the pole, then I could see where that might be a problem in high winds. All my poles have had a nice coating of rust on them by the time I got them, so I just coated them with some rusty metal primer and sunk that in the cement. There are still enough irregularities in the pole to make it nearly impossible to turn once the cement has hardened around it. Another thing I have done, if I think the pole might be just a little too smooth, is to take a sledge hammer to the end that will be in the ground, about a foot from the end, and try to beat it into a slightly oval shape, which will also prevent it from turning in the concrete. I don't know who has ever seen a pole turn in concrete, but if it's happened I suspect they either used the wrong kind of concrete, mixed it far too dry, or they somehow got a brand new, perfectly round pole with no imperfections at all to speak of. And I'll also bet that it took a hurricane or tornado to turn it.
I do make sure the pole is perfectly vertical while the concrete is drying but usually after about 20 minutes it is hard enough to stand on its own, and that's with regular concrete mix. I do NOT recommend using "Quikrete", the famously advertised stuff in the red bag, because it starts to set almost the second it is mixed, therefore it will not flow smoothly around the pole unless you are very quick to get it in the ground. And if it doesn't flow smoothly around the pole then you will definitely have a higher chance of the pole turning on you. The regular stuff (including the yellow bag version of Quikrete) takes longer to harden, but not that much longer to get firm enough to hold the pole upright, assuming you're not doing the install in the middle of a windstorm. And it will flow around the pole much better and grip it tighter as a result, as long as you add sufficient water. It also helps if you "tamp" the concrete, in other words jab it as deep as you can with a scrap 2x2 or similar piece of wood several times right after pouring to help get any stray air bubbles out, and that will also help force the concrete to conform to the pole. This is easier if you have two people, one to keep checking the level on the pole and make sure it doesn't get out of plumb while the other tamps.
I will say that where I live the ground is mostly sand, down to any depth you would dig. In fact it varies between layers of regular sand, which is pretty tightly packed after eons of being compressed by tree roots, and what we call "hardpan", which is sand that's so tightly packed that it's on its way to becoming sandstone. :) If I lived in an area where the ground liquified during heavy rains, or if I lived in an area prone to flooding then I would probably use a larger hole and more concrete. Of course if you live in an area prone to landslides then a couple truckloads of concrete might not be enough, so there is a tradeoff between how much you think you need and how much you can afford to spend, and also how much you want to mix by hand if you're not having a truck come in for the pour.
The main reason I prefer a minimal approach is that on at least a couple of occasions I've had to dig a pole out and move it, due to tree growth or some other reason, and it is a lot easier to do that if there's only 200 to 250 pounds of concrete stuck to the end of the pole. It's still a pain in the butt, but at least it's possible. If you follow the advice of some people and make a bell-shaped hole, you are probably never going to get that sucker out without a backhoe. But if the geology of your soil is such that that's what you gotta do, then that's what you gotta do. And obviously if you dig down a foot and hit solid rock, then your approach will also be much different. But don't just assume you need a ton of concrete; that may be massive overkill in many places.
Reactions: Titanium
Boy I do appreciate the response guys...so my scenario is 4" pole going in a 36 inch deep hole with is about 22" in width, sounds like 15 or so 60 lb bags?!
Wow more than I anticipated but what can ya do, can't get cement mixer in to my backyard unfortunately.
Question...do you pour in the cement in increments (allowing say the bottom half to set)? Or just fill the entire whole in at once.
Whole thing at once as fast as your able to. Never want to do it in stages, it will never be right that way, this I do know for certain. You want one complete strong form in the ground for the weight and wind load factors.
Reactions: Titanium and FTA4PA
One thing to also consider is how much of your pole is sticking above ground. This will drastically change the amount of concrete needed for your pole. In my case my pole is sticking 9feet above the ground and with the 10 foot dish installed is 14 feet to the top. So it would need more weight supporting it in the ground considering it does get pretty windy here. For a standard 6 foot fence here it is recommended to dig 3 foot deep and if using a 4x4 post a 12 inch wide hole. As far as something welded or sticking out the side of the pole it's a good idea mostly for the early curing cycle of the concrete or the first 28 days after that it would becom less critical. We even nail 16 penny galvanized nails into our posts for privacy fences as I have seen fence posts able to be pulled out of concrete just a week after setting. Ovalng your post would accomplish much the same idea, it creates an imperfect shape preventing movement and is something we do to chain link fence posts. I know I over did my concrete on my dish but it was more not changing the auger for one hole then anything else. And lastly there is the issue of drainage. I have repaired more then one fence that has suffered from rot from the bottom of the post up. There is only one way to prevent this and that is at a minimum sand in the bottom of your post and 4 to 6 inches of gravel is better. The dish I took out last year that had the tree fall on it had water standing in the bottom 2 foot of the pole. And over time it will rust away if left to stand. Who knows how long it will take but again better safe then sorry. I once read somewhere how deep and long a post should be for a typical dish install, and I recall somewhere in the neighborhood of 1 bag per foot of dish. But that was a year or so ago. Lastly I don't know ha good of an idea putting chunks of old concrete into a new pour is. I do know that the larger aggregate you put in any given mix the lower psi the concrete mix is (weaker). I would assume adding larger chunks of old concrete would create a weaker point in your concrete but you could be ok too.
Very good point Shicks4 makes about the length of pole out of ground and what is going to be on it. A pole with a large c band dish is gonna require a lot more base than one with say a 90cm on. ;)
Point noted regarding pouring the cement all at once!
So I lugged home 12 bags (50 lb bags) of the fast setting cement (see photo attachment - the home depot had this next to the pallet of bags).
I may pick up a few more to have just in case since I'm still not convinced of the formula, and I only got 50 lb bags due to my back...will let you all know how it plays out, still a couple weeks away from doing it.
So I am going to be cementing an 8' dish pole soon.
The hole is 23 in. wide (diameter) and 36 in. deep
anyone have experience with such a job...say number of 60 lb fast setting cement bags.
Is it square or cubic yards? or neither...thanks
When I put up a 10 foot Channel Master solid this summer the manual recommend a 2 ft diameter by 4 ft deep hole. The Lowe's concrete computer said I needed 26 50 pound bags which is what I bought. I used 23 which included filling the 5 inch by 7 foot pole. Even though it was the kind of concrete that you can dump into the hole and fill with water I was advised by a former installer to hand mix it. It took me right at 2 hours to hand mix it in a wheel barrel and set the pole. That dish isn't going anywhere.
That's why I got the 50 pounders. They had 60 and 80 pound also. I figured the lighter bags would take longer, but they would be easier on this 64 year old body. Surprisingly I felt pretty when I got out of bed the next morning.
Well I bought 4 more 50 lb bags today, bringing the total to 16, my hole is a foot shallower and if I don't fill up my pole that brings me close to your amount, thanks, may pick up a couple more???
Try to leave some for other people who are planting their own poles somewhere! Don't be a Quickrete Hog!! LOL!!! You would think that stuff is going out of style!
Reactions: Titanium
I had to dig three piles 18" dia X 8ft for my 10 footer in clay soil. Didn't want it to move. Had several yards of cement gravel dropped off nearby and a pallet of cement mix (not ready-crete, this stuff you have to add gravel), and rented a cement mixer for the day, and a garden hose available to supply water right at the mixer. Also used rebar in the piles, and 1/2" X 3ft threaded plated rod for the anchors with a short 90deg bend at the bottom.
Again, this is real gumbo/clay soil, frost line is at least 6', and we get a lot of high winds way out here...
An advantage of a tri-pod system is that if anything ever moves, you can easily re-level the assembly to get a vertical pole again.
For this kind of "stuff", I like to figure out what is required, and add another 25% or so just to make sure it lasts.
Great advice above too!
well today I cemented my 7.5' pole for my 8' dish, in to the ground - it ended up taking 12 50lb bags to fill the hole, the hole was 36" deep and about 22" wide...hope to have the unimesh dish on it by month's end! see photo attached
I just removed a pole that had a 7.5' solid dish on it yesterday that had probably about the same amount of cement you used on it. It was in there pretty good. I dont think you will have much trouble with it. Depending on the temps where you are you could probably put that unimesh dish on there in a few days.
hey another question, any advise on protecting the cable from the elements and avoiding contact with the cement and pole, I just realized I could have cemented a conduit in to the cement base.
Really no reason to protect the coax at the dish. I have had mine in the open from the LNB, down the support arm, under the dish and attached to it, down the pole to a 3/4" plastic water pipe. Then it runs in the pipe to the house. The actuator and sensor wires are in there also. Coax out in the sun and dam cold here has lasted for years. Just be sure to seal the connector at the LNB to keep the water out.
