How many more channels can be added to 119, 110??
G&T
41
California
I'm just curious; I'm sure that space is limited, but limited to how many channels?
*Also, how many channels can be added to other sats'??
go to lyngsat.com
Count the number of video channels in each transponder. Usually they consider a TP full when it has 12 video channels and nothing else.
If you find some transponders that have less than 12 video channels than there might be some room.
Good luck :)
Here is the situation as of today:
61.5 degrees west longitude
tp - channels uplinked - space left
1 - 3 HD - 0
2 - 2 HD - 1HD?
3 - 3 HD - 0
4 - Unused DISH
5- 2 HD - 1HD?
6 - 14 (several audio) - 0
7 - 2 HD - 1HD?
8 - 9 (several tests) - 3?
9 Unused VOOM
10 - 10 (1 audio 1 data) - 4?
11 - Unused VOOM
12 - 15 test channels - 0?
13 - Unused VOOM
14 - 9 - 3
15 - Unused VOOM
16 - 11 - 1
17 - Unused VOOM
18 - 12 - 0
19 - Unused VOOM
20 - 9 - 3
21 - Unused VOOM
22 - 14 (2 "reserved" spaces) - 0
23 - Unused Unassigned
24 - Unused Unassigned
25 - 19 (9 audio) - 0 (Sky Angel)
26 - 10 - 2
27 - 11 - 1
28 - Unused Sky Angel
29 - 8 (1 EPG) - 4?
30 - 11 - 1
31 - 12 - 0
32 - 17 (7 audio) - 0?
At 105 degrees WL
1 - 11- 1
2 - 10 - 2
3 - 6 - 6
4 - 9 - 3
5 - 12 - 0
6 - 9 - 3
7 - 9 - 3
8 - 12 - 0
9 - 12 - 0
10 - 12 - 0
11 - 12 - 0
12 - 11 - 1
13 - 12 - 0
14 - 12 - 0
15 - 12 - 0
16 - 12 - 0
17 - 9 - 3
18 - 6 - 6
19 - 11 - 1
20 - 12 - 0
21 - 10 - 2
22 - 12 - 0
23 - 12 - 0
24 - 12 - 0
Dish does not currently control any more TPs at this location.
110 Degrees West Longitude
1 - 10 - 2
2 SPOT BEAM
-4 - 12 - 0
-6 - 12 - 0
-7 - 12 - 0
-10 - 12 - 0
-12 - 12 - 0
-3 - 13 (1 Mirror) - 0
4 SPOT BEAM
-5 - 7 - 5 (Colorado Spot)
-9 - 13 (1 mirror) - 0
-13 - 12 - 0
-15 - 8 - 4 (Caribbean spot)
-5 - 13 (1 Mirror) - 0
6 SPOT BEAM
-1 - 12 - 0
-9 - 12 - 0
- 12 - 12 - 0
- 13 - 12 - 0
- 26 - 13 (1?) - 0
7 - 2 HD - 1HD maybe...cannot mix HD and SD on same tps at this time
8 SPOT BEAM
- 2 - 11 - 1 (Central Calif)
- 6 - 13 ( 1 mirror) - 0
- 7 - 12 - 0
- 10 - 12 - 0
9 - 12 + 1 data - 0
10 Spot Beam
-2 - 12 - 0
-7 - 14 - (2 mirrors) - 0
-8 - 12 - 0
-10 - 12 - 0
-12 - 12 - 0
11 - 15 (3 mirrors) - 0
12 - 10 - 2
13 - 5 HD (2 inactive at any one time) - 0
14 - 12 - 0
15 - 12 - 0
16 - 16 (4 mirrors) - 0
17 - 3 HD - 0
18 - 13 (1 mirror) - 0
19 - 0 - 3 HD or 12 SD
20 - 12 - 0
21 - 6 - 6
22 - 13 (1 data) - 0
23 - 14 (1 data + 1 mirror)
24 - 15 (only 12 active at any one time) - 0
25 - 12 (one mirror) - 1
26 - 15 (1 audio+ mirror, Bingo & BTV share 1) - 0
27 - 12 (1 "slate", 1 mirror) - 2
28 - OWNED BY DIRECTV
29 - 12 (1 nine day epg, 2 data high volume) - 1 maybe
30 - OWNED BY DIRECTV
31 - 11 - 1
32 - OWNED BY DIRECTV
119 degrees west longitude
1 SPOT BEAM
-3 - 12 - 0
-5 - 12 - 0
-9 - 12 - 0
-13 - 12 - 0
-15 - 11 - 1 (South Fla)
2 - 48 (24 audio, many mirror) - 0
3 SPOT BEAM
-3 - 13 (1 mirror) - 0
-5 - 11 - 1 (South Calif.)
-9 - 11 - 1 (Oklahoma)
-13 - 12 - 0
4 - 35 (16 audio, many mirror) - 0
5 SPOT BEAM
-4 - 12 - 0
-6 - 12 - 0
-10 - 13 (no mirrors I see) - (-1)
-11 - 12 - 0
-14 - 12 - 0
6 - 16 (1 audio, many mirror) - 0
7 SPOT BEAM
-4 - 12 - 0
-6 - 10 - 2 (Arizona)
-10 - 12 - 0
-11 - 12 - 0
-14 - 14 (2 mirror) - 0
8 - 26 (8 audio, many mirror) - 0
9 SPOT BEAM
-1 - 10 - 2 (Hawaii)
-2 - 8 - 4 (Alaska)
-7 - 12 - 0
-12 - 12 - 0
--inactive spot beam aimed at Mexico
10 - 9 (sports & movie channels) - 3
11 - 14 (3 mirrors) - 0
12 - 32 (11 audio, many mirror) - 0
13 - 28 (12 audio, many mirror) - 0
14 - 13 (1 mirror) - 0
15 - 30 (6 audio, many mirrors) - 0
16 - 23 (7 audio, many mirror) - 0
17 - 17 (7 audio, 1 mirror) - 2?
18 - 29 (18 audio, 2 mirror, 1 slate) - 1?
19 - 22 (14 audio, 2 mirror, 1 slate) - 2?
20 - 48 (15 audio, many mirrors!) - 0
21 - 31 (21 audio - 2 mirrored) - 0
22through32 owned by DirecTV
121 West Longitude
tp - channels - room for
1 - 5 - 7 (Local)
2 - 6 - 6 (Local)
3 - 4 - 8 (Foreign)
4 - 9 - 3 (Foreign)
5 - 11 - 1 (Foreign)
6 - 10 - 2 (Foreign)
7 - 10 - 2 (Local)
8 - 6 - 6 (Local)
9 - 6 - 6 (Local)
10 - 11 - 1 (Local)
11 -10 - 2 (Local)
12 - 8 - 4 (Local)
13 - 10 - 2 (local)
14 - 12 - 0 (Local)
15 - 10 - 2 (Foreign)
16 - 9 - 3 (Foreign)
17 - 11 - 1 (Foreign)
18 - 7 - 5 (Local)
19 -9 - 3 (Local)
20 -12 - 0 (Foreign)
21 - 8 - 4 Foreign/local
22 - 8 - 4 (Local)
23 - 7 - 5 (Foreign)
24 - 5 - 7 (Local)
25 - 6 - 6 (Foreign)
26 - 10 - 2 (Foreign)
27 - 12 - 0 (Foreign)
28 - 10 - 2 (Local)
29 - 9 - 3 (Local)
30 - 6 - 6 (Local)
31 - 0 - 12 SD or 3 HD
32 - 0 - 12 SD or 3 HD
148 Degrees West Longitude
1 - 15 - 0
2 - 10 - 2
3 - 9 - 3
4 - 10 - 2
5 - 5 HD test & data
6 - 7 - 5
7 - 10 - 2
8 - 5 - 7
9 - 10 - 2
10 - 13 - (-1)
11 - 12 - 0
12 - 9 - 3
13 - 2 HD - 1 HD?
14 - 11 - 1
15 - 8 - 4
16 - 12 - 0
17 - 2 HD - 1HD?
18 - 4 - 8
19 - 8 - 4
20 - 22 test channels) - 0?
21 - 8 - 4
22 - 6 - 6
23 - 19 (test channels) - 0?
24 - 0 - 12 SD or 3 HD
25 - 4 - 8
26 - 0 - 12 SD or 3 HD
27 - 12 - 0
28 - 0 - 12 SD or 3 HD
29 - 9 (2 mirror) - 5
30 - 0 - 12 SD or 3 HD
31 - 8 (4 HD test each mirrored once) - 0
157 Degrees west longitude
32 transponders 3 lit up with mirrors, otherwise all available.
Hope that helps :)
THERE IS PLENTY OF ROOM ON 61.5 & 148
According to the above list, there is plenty of space available on 61.5 to add the remaining 11 HD channels. Also, it seems that there is plenty of space on 148 to add ALL VOOM HD channels. I roughly counted transponders with space for 4 SD which is equivalent to 1 HD channel.
GET ON WITH IT DISH ! MIRROR THOSE VOOM HD TO 148 !!!
Actually I see room for 20 more SD channels at 110° or 3 HD and 8 SD. This is tops! TP 19 at 110° is empty accexcept for a data "home" application. This is where 12 of the 20 SD channels could go or up to 3 HD channels. Remember that at this point Dish cannot mix HD and SD channels on the same transponder due to their current encoding scheme.
See ya
Tony
And of course the numbers will change over the next year(s) with MPEG 4. The satellite will amp and reflect back MPEG 2 or 4 or whatever plus the new satellites going up. But when will the uplinks & receiver conversation allow the complete switch over to MPEG 4 is an other question.
Perhaps Dish is holding back on certain transponders so they can be used for MPEG 4 in fall '05 or after. Some deal will likely be offered for upgrading receivers to MPEG 4. but using existing sat locations saves the expense of repositioning Dishes. If this is the case the unused transponder space will be held back. I do not know, it's just a guess on my part.
They can put a lot more channels on 119/110 if they want to upgrade all the receivers. Dish is finally decided that upgrading all the receivers is going to be done. When they finally get all the receivers changed they will be able to do 2 things:
1. Change all transmissions to 8PSK (from QPSK or 4PSK) this will give them 30-40+% more space
2. Change the content from MPEG-2 to MPEG-4. This could cut the space used by HD and STD by about a third. People like to quote a 1/2 space savings, but in reality most HD MPEG-2 is running at 12MBit/sec or less on average (down below 19.2) as the encoders have gotten better, the rate continues to drop some on MPEG-2. HD MPEG-4 will probably start around 8MBit/sec and work down to 5-6 as the encoder get better.
So, lets say 10 standard definition channels look good now on a TP, in the future 8PSK will raise that to 14, then MPEG-4 probably will raise it to 21-22/TP.
It should be note that at 105 W, there will be only 24 Ku band TPs even when AMC-15 is moved there later this month but the Ku band frequency range is the same as Echostar-9 at 121 W with its 32 TPs. The low power of AMC-2 at 105 W requires Dish to use large error correction which limits the number of SD channels/TP to 12. With the much higher powered AMC-15 at 105 W, Dish should be able to do up to 16 SD channels/TP. Based on the post by TNGTony, this should allow Dish to add 120+ SD channels to 105 W with AMC-15. I would expect Dish to use AMC-15 at 105 W for more local markets based on some of the information from the Team Summit.
Keeping distant locals
811 Setups Tips For Voomers
